C5 brake conversion
I'd also suggest looking into some of the 4 piston Brembo swaps. If you are going to buy calipers, rotors, pads, etc it will be very minimally more to get a 4 piston Brembo setup from a C7 / ATS / CTS-V / Camaro, and you'll get a much firmer pedal feel with the fixed caliper.
There are lots of threads on here about them, but in a nutshell the C7 JL9 / ATS swap uses 12.6" rotors and will fit under OEM 17" wheels. Only added expense you might need is wheel spacers for the spokes to clear the calipers. I did this swap and got ATS Brembo calipers from Amazon for under $150 each. It's not super organized, but the "Best brake upgrade stock SS wheels" thread just below has lots of details on this swap for part numbers and part compatibility.
Then there's also the CTS-V 14" rotor swap as well, which uses very similar calipers but the larger rotors, so you need at least 18" wheels to comfortably fit. There's a sticky at the top for that swap.
That's just my two cents - C5 swap will still be an upgrade, but for very similar cost I'd rather spend the money and time on a Brembo setup.
