Eliminated Wheel Hop, BUT its Back!
Hey guys,
I have a 98 M6 Trans Am and it had koni yellows, a muffler and wheel hop. I bought non adjustable poly rear control arms with relos along with longtubes, a tune (315whp), poly motor mounts, rubber trans mount, and poly torque arm mount.
I havent had wheel hop since until now. When I slam 2nd gear at full throttle, I get hop. My tires are 1 yr old mickey street comp non drag radials.
Is there anything I can check to fix this. I havent driven the car much this summer, only went through a tank and a half of gas. The last time I drove the car, there wasnt any wheel hop shifting into second. I usually lift the wheels off the ground during winter storage but this year I haven't. Not sure whats going on, any opinions?
Yes, exactly. I havent had wheel hop in this car since upgrading control arms 4 years ago. Last week, when I took the car out, felt hop on 3 1st-2nd upshifts. Shitty feeling.
just my one cent i had bad wheelhop when i bought my car. after adding welded SFC; LCA's; & panhard bar (all 3 same time) that eliminated my wheelhop issue. i've since added TA just for peace of mind. im running original shocks. cheers.
Rubber trans mount? Bet you its broken
Do a visual on all parts under there for starters. These issues dont magically happen and most suspension problems you can see. Failing that pop each lower shock mount off and hand pump it to see if its not blown, look for leaking fluid first. Often gas leaks out and oil is fine but that shift in suspension pre load without gas charging could also cause this.
LS1Tech Premium Sponsor
^ I second this. Also check the torque arm mount. I have seen more than a few come loose or break and cause these issues. Also double check the torque on the bolts attaching the torque arm to the rear end
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
