97 ws6 ride height
97 ws6 ride height
Im just wondering if anyone noes what the ride height on theese cars are. I measured mine on level ground and the back is 28.75 and the front is about 26 maybe 26.25. To me tbe front seems to sit low so i didnt no if someone maybe changed the springs on the front. Ive changed the shocks put konis all around koni yellows sports
Not sure about tje ride height on the konis. I no they can b used with lowering springs or factory springs. When i talked to the guy at bmr he said with there lowering springs 1.25 drop the front would sit at 26and the rear would b 26.75 well my front is already at 26ish
Actually those lowering springs will only drop you roughly 1.25" from where you're currently at if you're at stock height. So that means there is no specific number set in stone. Every car will be a bit different
