What Else Is Needed On Suspension To Be Complete?
Springs:
- Sam Strano lowering springs
- Every mount related to springs / suspension when doing the springs and shocks was replaced with MOOG and OEM parts where and when applicable
- New poly bumper stops
- 99 thru 04 cobra rear spring isolators (gives more of a drop)
Rear Suspension:
- Poly / Roto single on car adjustable panhard bar
- Poly / Roto single on car adjustable LCA’s
- Bolt on LCA relocation brackets (now welded on)
- Powdered Coated OEM upper panhard bar
- UMI upgraded rear sway bar
- UMI billet rear sway bar mounts
- UMI rear sway bar axle mounts
- Energy suspension rear sway shorter end links
- UMI full length adjustable torque arm
- UMI transmission mount relocation cross memeber (Automatic Transmission) takes Torque Arm off tailshaft
- Bilstein HD shocks
- Stainless Steel brakelines (J&M WS6 Store)
Front Suspension:
- UMI upgraded front sway bar
- UMI billet front sway bar mounts
- Blaine Fab powder coated front heavy duty sway bar mounts
- Energy Suspension front sway links (need to go shorter link)
- UMI 2 point Strut Tower Brace
- UMI 2 point Weld In Subframe Connectors
- Sam Strano Brake Master Cylinder brace
- UMI tunnel mounted drive shaft safety loop
Rear End:
- TA Performance Differential Cover
- TA main stud kit
- Richmond MEGA rear end rebuild kit
- Brand NEW Motive Orange Box 373 gears
** Looking to buy UMI front upper a-arms (probably non-adjustable),UMI front lower a-arms (probably adjustable), UMI front upper a-arm mounts, UMI k-member, UMI Delrin steering member inserts.
***Just bought Rotoworks Slotted ONLY set of rotors (4), HAWKS HPS front and rear pads (WS6 Black Friday / Cyber Monday sale).
****Rebuild kit included all NEW TIMKEN bearings, seals, spider gear in the rear end. Every single seal and bearing was replaced and upgraded.
is there anything suspension wise I can add?
Thanks in advance!!
- Mega Bearing Kit Includes Timken Bearings (Axle, Carrier, Front and Rear Pinion, Pilot where applicable), Brush, Cover Gasket (or RTV), Crush Sleeve (or Preload Shim Pack), Marking Compound, Pinion Nut, Ring Gear Bolts, Seals (Axle, Pinion), Shims (Pinion, Carrier), and Thread Locking Compound
i see zero benefit of chromoly Over mild steel for my application except my wallet being a lot less lighter.
my car is pristine condition so no I don’t want to tear it all apart for a “race car”.
I am with you on the chromoly, that is pretty much unneeded, but the option is there for people that want it, for whatever reason.
You don't say what size or kind of swaybars you put on. Size and kind matter (solid or hollow) for how you plan to drive it. FWIW, I autocross a lot and I still have the stock rear bar.
Not upgrading brake calipers? No watts link?
The bigger question is, what do you want to get out of driving your car? Autocross? Just street? Doing a track day or two? Because not all those parts really make the car faster, smoother, or improves handling, just lighter wallet. You could replace every single piece on the car, but what's end result for you?
Of course I have all the UMI parts if you want to talk about those things missing you mention up front. But for instance, if you run non-adjustable upper arms, you can't use the upper mounts that allow you to change your camber curve and anti-dive geometry. Another thing you may, or may not wan to do.
On the fact of it, the brakes are lacking, the shocks are lacking. Watts link are biggies. I would do a K-member before actually worrying much about arms, depending on what parts you used in the rear "caster" bushing location. And then I might just do lowers, or maybe just uppers. Again. situation, and budget dependent.
I bought the shocks way back when as i could not afford Koni’s (now are double adjustable better than single adjustable)? I know UMI makes a kit now that turns the PH into a watt link system.
Car is a street car, want high HP and just an overall around fun car.
plan is 383 forged either nitrous or super charger, 9in, built 4L60E (either 700 HP or 1000 HP version); looking at the “black edition”, companies such a small performa built, FLT, RPM transmission. Heads probably AFR / AI or LE, custom cam to match. Currently has 373’s with a rebuilt rear end for right now. Probably get yank billet 3 piece 3600-4000 stall, shift kit HD TRANS GO 2.
everything is on car single adjustable for suspension FYI. Poly Roto UMI
had zero idea the autocross is here, don’t even know where it’s held in Lincoln Nebraska. I’m more in the street scene.
Sway bars: sway bars 35mm front and 22mm rear
Mounts: HEAVY DUTY ALUMINUM SWAY BAR MOUNT KIT- 35MM & 22MM SWAY BAR KITS
axle mounts: AFTERMARKET REAR END SWAY BAR INSTALLATION KIT- STOCK REAR
im one of those people if I am going to replace stuff I’m going to do everything.
bugdet was an issue when I bought my shocks.
however all the pieces for my suspension only has less than 250 miles on it just fyi
