BMR torque arm relocation help
The car is jacked up in the front and supported by the axel tubes in the back. I have the crossmember loosely bolted up at the 4 corners and transmount and the bracket is attached to the bushing with the open side facing the driver side, so the arrangement if looking from the back of the car is crossmember plate--metal spacer--bushing bracket--tailshaft.
The car is an auto so im not sure if i even have the bracket on the right side of the plate now because ive read some contradicting info.
Please help, i need to have the car back on the road by monday.
thanks.
On side note, I was only able to get the mount on the 4th home from the bottom. I was just happy to be able to mount it. I know stock is supposed to be 3rd from the bottom, is there any danger in having it on the fourth hole at stock spring height?
I also seem to have lost the ability to place a socket on the trans mount nut because there's no clearance when everything is mounted up. I had to use a wrench to tighten up the trans mount nut. Is this normal?
