S60 torque arm rear fitment
Hey guys, I recently installed an s60 rear and driveshaft into my Camaro and a UMI torque arm. The torque arm driver side bolts that mount the torque arm to the rear are hitting the body. (Red arrow in picture). NOT MY CARS UNDDRBODY, just using it for reference as I’m at work. I will post what I have under it. My question is, can I BFH mod the panel in so that the torque arm bolt clears or is there something behind that, that could mess something up. Thanks in advance.
Just above this area.
My actual cars current setup
Are you using the inner most set of holes on your torque arm bracket? If not, you have to trim the outer set of holes off to allow you to use the inner holes. I have plenty of clearance with my S60 using this method and my car is lowered.
https://ls1tech.com/forums/suspensio...acket-s60.html
There is a picture in the link above showing what I am talking about.
The 2nd set of holes is included for this purpose. One problem however (not a quality problem, just a packaging problem of trying to fit 10 lbs of heavy duty stuff into a 5 lb bag) is larger u-joints tend to be pretty close in there so don't cut without careful measurement.
We have an S60 in our 2000 WS6 and it uses the standard holes and a little bit of floor modification.
ramey
ramey
What do you mean u joints? On the driveshaft itself for the rear? Should I not cut it down and just hammer in the floor panel? Also, do you guys have an overlay or something to show you exactly where to cut, I saw BMR has overlays they can email you.
I should have said rear yoke. If you have a giant aftermarket rear yoke on the axle, clearances can get tight.
We don't have a template at the moment. You simply remove enough material until you can utilize the inner set of holes. Axles vary in how much needs removed.
It's very common to clearance the floor pan when running UMI or other brands of aftermarket torque arms. I'd start with that.
You're totally fine to BFH the floor in that area, it's under the rear seat. I'd still try to move it to the inner holes though if you have the clearance from the yoke. I'll be putting my car on the lift tomorrow I can post a picture of how mine looks with a trimmed Spohn TA, S60, and Stranos.
The following users liked this post:
GHall8788 (01-27-2020)
