K memeber
Old Oct 2, 2019 | 11:25 AM
Kdthunt's Avatar
Default K memeber
Curious to general opinions on aftermarket k members. Pro and cons of the different brands. Fitment concerns and overall quality. tia
Old Oct 2, 2019 | 11:55 AM
UMI Tech's Avatar
UMI's twin tube design k-member is well regarded, strong, Made In USA and has great fitment. They save approx 25lbs and give more clearance for headers and so forth.
Our road race version has roll center height optimization and turns-in like a Vette.
Check 'em here.
We'd be happy to answer any questions you may have.
Old Oct 2, 2019 | 02:31 PM
MidwestChassis2's Avatar
The Midwest Chassis k-member can utilize either the factory power steering or manual rack plus either stock A-arms or aftermarket A-arms that are designed for the factory style slotted A-arm mounts using factory bolts. Our standard K-members with engine stands accepts up to 5" downpipe on the passenger side (without a/c) and up to 3.5" on drivers side. The driver side can accept up to a 4" downpipe if you do a manual rack conversion. The turbo version k-member allows for the use of the a/c compressor and a 4" downpipe on the passenger side.
To this day we still check every K-Member for fitment in our test vehicle. Not only for mounting purposes but to insure it fits properly to the motor. Durability has never been an issue. Any questions please feel free to hit us up.
https://midwestchassis.com/products/...ebird-trans-am
Old Oct 2, 2019 | 08:52 PM
Floorman279's Avatar
I'm goona get a ton of static from this, but the giant ugly heavy stock piece is the strongest and most durable k member. I chose the stocker for my build. however the umi road race is a really sweet piece for a 90 percent race car. just wanted to throw that out if u were unfamiliar with that
Old Oct 17, 2019 | 12:33 PM
legen-waitforit-dary's Avatar
Check 'em here.
What is the weight difference between the road race version and the original UMI k member?
Old Oct 17, 2019 | 12:35 PM
UMI Tech's Avatar
The general amount we mention is the road race version adds 3 lbs. There are options like rod ends, which engine mounts you choose and so forth. So, if the standard version is at 25 lbs, the road race tends to weigh 28.
All of this is with a grain of salt, as options happen.
Old Oct 27, 2019 | 11:58 PM
Dragframe's Avatar
If I could go back I’d buy a K member from you guys. I have a bmr with a manual rack conversion from you guys. I put solid mounts in it and the trans is a 1/2” off at the mount. Even after loosening everything and using a chain house to pull the k member it is still off. I’m gunna have to cut the motor mounts and weld them on straight! Wth right?!?
Old Oct 28, 2019 | 05:31 AM
38DD2436's Avatar
I just got my UMI road race K. Will be installing next week. I will let you know how it goes.
