Weld On SFC’s with Seat Brackets
Are UMI’s boxed steel completely different than Midwest’s as well? I emailed Midwest asking where there’s weld up so I can figure out what makes there’s “better” and their response wasn’t very informative. They said, “Weld anywhere that there is contact.” Well, no kidding..
I emailed Midwest back asking if they could elaborate on why there’s are “better” than the rest. I have a feeling they will compare their square tube with others round tube. Other than that I think they all get welded at the same points. Other than those who provide a bolt to run through the LCA as well get welded around the LCA “cradle.” But really I think their ad: “Do not be fooled by other companies on the market that have multiple point SFC or bolt to the LCA mounts,” is just comparing weld-in to bolt-in SFC’s.
The following users liked this post:
Tyler Dietzenbach (02-06-2022)
https://midwestchassis.com/products/...-powder-coated
The weld on subframe connectors stays on the subframe and does not incorporate the LCA's while the BMR's boxed ones that can be bolted or welded do. Is there one that's better than the other? That's subjective, but think of it's purpose and use then decide!
UMI
Midwest
Midwest
UMI
I like the Midwest Chassis SFC's.
Tyler Dietzenbach (02-07-2022)
Can you elaborate as to why?
Has anyone had any negative experiences with the type that weld to the LCA “cradle” or bolt to the LCA? Is a piece of round tube steel that is welded to outer part of the frame towards the door really doing much to help distribute the load more evenly?
The following 2 users liked this post by 01CamaroSSTx:
bbond105 (02-06-2022), Y2K_Frenzy (02-06-2022)
I like the fact that it is closer to the driveline and connects both of the subframes. Some work will need to be done to the flooring to get the connectiors to mate nicely but once all that's welded together I feel this would be the most structuraly sound way of doing it.
Also, just how much modification is needed El get Midwest’s to work? Enough to scare off a muffler shop from wanting to do the work so I guy has to find a custom chassis fab shop?
One more question. Does having the LCA tied to the frame via SFC hinder the rear axle’s ability to articulate?
“Our frame connectors do not contact the LCA bracket at all. The LCA bracket is 6” away from the actual subframe and not even the same piece of metal, plus it is plenty rigid and no additional support is beneficial. The MWC connectors actually connect the true subframes where the best benefit of adding the component to stiffen the chassis will be effective. A lot of the other designs will only attach at the outer portion of the LCA bracket and run along the pinch weld which is already the strongest point of a unibody chassis. Some designs will even stop short of the front subframe and only focus contact at the floor crossbrace. The MWC connectors are only available in a weld-in design and attach to the actual front and rear subframe rails to do the job they are intended for.
MWC Sales Team”
The following 2 users liked this post by Y2K_Frenzy:
01CamaroSSTx (02-07-2022), Tyler Dietzenbach (02-07-2022)
To me it sounds like their subframe connectors would be the best design if you want weld-ins. Seems like other companies like having just 1 design that can be both bolt and weld. Which does make sense for them from a financial perspective. This design should have better rigidity than the others.
I know when I hit the market for SFCs that the MWC ones will be my first choice, as the design makes the most sense. Thanks for doing the research for us and all future thread readers.
#32
Really the only reason I’m looking at SFC’s is to try and prevent the chassis to sag like an accordion. Mine has T-tops. Am I worried for nothing? Not just the “accordion sag,” but what about door sag? Is that common? Will SFC’s help this not to happen?
