Assistance on upgrades to help hook
Front shocks are stock (I have some Konis, not in yet)
Rears are Koni Sport
stock springs
stock torque arm
stock lcas (I bought 1LE bushings to install)
stock 16" wheels (I know..)
Obviously you see above some upgrades are planned already.
Where should my priorities be? Perhaps an order of operation, that would be nice to follow. Suspension setup is a new ballgame to me. I have no interest in running coilovers or a crap load of NVH, I can deal with some.
Kevin Wilson SBC Kevin Wilson - YouTube has some very good videos on f-body torque arm suspension. Anyone who is trying to drag race an f-body needs to watch his videos.
At a minimum, you need a better torque arm and some LCAs. Addind SFCs, LCA lower control arm brackets and an adjustable PHR is even more of a benefit later on
The adjustable PHR will be adjusting your thrust to make you go straight.
Then after all thats done and you're on a sticky tire...kiss that 10 bolt goodbye. Stock driveshaft will probably twist and if you're an A4, a stock 4l60 gonna have 4 neutrals.
Also know this, The UMI torque arm uses a DS loop that hangs way down and they won't fix this problem. So I used the BMR which completely tucks the loop up in the car.
Shop wisely.
EDIT: also if you don't invest in adjustable parts and your pinion angle is wrong, you will get severe wheel hop and break a lot more than just one part.
Shop wisely.
Boxing the stock LCAs and using 1LE bushings will be just fine for my needs. No reason to run roto joints and poly binds. I'll be fine with that.
I agree that a better torque arm would likely help. Wouldn't I only need an adjustable panhard bar if I decide to lower?
Yes I'm well aware of the trans and rear issues that are in my future. I have an auto, which is mentioned above.
