Throttle Position Controller Module
Old May 3, 2022 | 04:25 PM
Aganger58's Avatar
Default Throttle Position Controller Module
I have a "SERVICE VEHICLE LIGHT" and brake light on and the code is the ebcm (u1040 and u1000). Replaced the ebcm and still have the code and light. Everything ive looked up is that it could be the Throttle position controller module located under dash...except can't find any pictures or anything saying exactly where it is? Dont wanna start tearing apart dash and be taking off wrong thing. Anyone have pics of location or a link to something on how to go about replacing it?
Its a non-tcs car also.
Thanks
Old May 3, 2022 | 06:32 PM
bbond105's Avatar
It would help if you told us what vehicle you are working on.
Old May 3, 2022 | 06:46 PM
Aganger58's Avatar
Its in my footer...2002 Camaro!
Old May 3, 2022 | 06:53 PM
bbond105's Avatar
I don't think a 02 Camaro has a throttle position controller module, as they are drive by cable. I could be wrong though.
Old May 4, 2022 | 09:56 AM
wssix99's Avatar
Save the manuals!
There is a Throttle Position Sensor (TPS) on the Throttle Body, but that's it. The rest of the mechanism is a cable connection.
If you are still getting the EBCM codes, I would look to a bad EBCM again (did you get a used part???) or a wiring problem before an anciliary sensor. I would expect a TPS problem would throw a TPS code.
Old May 4, 2022 | 02:11 PM
Aganger58's Avatar
Yes a used EBCM. It drives just fine and didn't start getting this till after i replaced my knock sensors and radiator hoses. But i might not worry about it since it drives just like it did before the lights came on.
Old May 4, 2022 | 05:23 PM
Aganger58's Avatar
Disregard...decided to check the ground cable on the radiator support, yep just a lil loose. Tighten it up and now no more dash lights!
Old May 4, 2022 | 10:01 PM
bbond105's Avatar
Good deal! Glad you found the problem.
