QA-1's squeek!!!!
Old Jul 25, 2004 | 08:49 PM
CAMSS30's Avatar
Default QA-1's squeek!!!!
I have QA-1's on all 4 corners with Eibach pro kit springs and various other suspension mods, The QA-1's have been on the car for about 8,000 miles if that. They have been great up in till about 2 months ago when i noticed them starting to squeek a little, Now they squeek realy bad. I pulled on out and there is no evidence of them leaking??? The fronts are not making any noise just the rears??? I ussually have them set at 6 all the way around and sometimes 7. My question is wtf is the problem with them and who else has this problem? According to QA-1 they have never had any complain about this problem???
Old Jul 25, 2004 | 09:31 PM
2w0s060's Avatar
I have never heard on an issue with QA1, I run them and really like them. I know rod ends make require some maintenance for help the life of them. I have read to clean them in Mineral spirits and let them Air dry, they place some oil on them and reinstall. I have nver done this, just read it. Try QA1's site and see if there is any maintenance required or cleaning?
Old Jul 25, 2004 | 11:17 PM
John95Z28's Avatar
You mean QA1 (HAL) drag shocks, right? For a minute there I didn't know whether you meant you had shocks which squeak or a suspension component like a LCA with QA1 spherical rod end bearings which are squeaking
Squeaky shocks or squeaky bearings?
Old Jul 25, 2004 | 11:35 PM
trackbird's Avatar
Squeaky shocks. Unless he has his rod ends set on "6".
Old Jul 26, 2004 | 12:10 AM
John95Z28's Avatar
Good call What IS the recommended setting for rod end LCAs, anyway?
"Set phasers to KILL"
Old Jul 26, 2004 | 08:29 AM
2w0s060's Avatar
ha, stupid me, I guess I jumped the gun to quick. When I heard QA1 I automatcally assumed rod ends. Oh well I tried.
Old Jul 26, 2004 | 09:32 AM
jimmyblue's Avatar
Moderator
Could be the shock mounts or any of the other
rubber bits, needing some grease &/or tightening.
I don't have HALs but still get squeaks every 6
months or so if I don't re-grease the sway bar links
and bushings.
Old Jul 26, 2004 | 08:01 PM
CAMSS30's Avatar
I pulled the shocks out and they make a squeeking noise when compressed so it is in the shock it self, Anyone have this problem? These things have 5 to 6 thousand miles on them only.
