Help - Adjusting pinion angle
I read it with a digital angle finder on the harmonic balancer. Not the bolt.
UMI checked from driver side and got negative angle. I checked from driver side and get a positive angle. Every video or thread I read gets a negative angle on the drivers side.
Am I suppose to read from the drivers side or passenger side?
if driver side why am I getting a positive angle?
Edit: I bought a new angle finder so I’m no longer confused. Answered my own question.
Does this mean you got your angles in spec?
yes should be all set
final
front tail down 3.4
rear nose up 1.4
= -2.00 pinion angle
if u can confirm?
Your angle at the pinion yoke should be within 1° of the angle measured at the tailshaft. You're trying to account for the slop in bushings, as the axle will rotate up slightly under acceleration load.
If I read your numbers as this, you pinion needs to come up 1 more degree, assuming you're setting this up for street driving. Then go drive it down the highway between, 65 and 75 mph, and see if it runs smooth.
I would try to get the 1.4* number to 2.4*, go drive the thing and see if you get vibrations between 65-75mph.
https://www.umiperformance.com/home/.../2200-2203.pdf
Did u read the measurements?
