BMR TRACK PACK T/A broke!!!!
my BMR trak pak torque arm snapped on street tires while on the street... after about 10 12.3-12.4 runs at the track a few weeks before
it broke the bar right at the center bars weld (the weak spot)
what can be done or am i just SOL? my entire car is BMR'd out (minus the front end which will be soon especially if this is resolved) and after this happened i see posts on the board where other ppl have broken there BMR things.
I hate posting this but BMR blew me off and i don't weant other ppl to get stuck being a bunch of new parts because there BMR can't handle a 12 second NEAR STOCK ls1
you got anypics of where it broke or can you get some id like ot see what you talking about i been running the trac pake over a year and no problems only thing i keep breaking is my pinon gear i nthe rear end
Eddie
Eddie
If they were to not fix this or send you a new one (as this could somehow be a fluke) then i doubt i could sell BMR at my shop anymore... But i always give the manufacturor a chance to step up the plate and make good on things like this, and when they do, it makes them look that much better for it (i.e. AP engineerings recents changes after problems makes them look even better than before they had the problems)
BMR is getting hit by Frances right now. Pretty much all of Florida is shut down at the moment. I'm sure they will take care of any problem you may have after this is over.
that sucks that happend man. i whould call them and ask ot tal kot frank he is the main tech guy and very frindly to talk to. he can point you in the right direction.
like i said i have had my trac pak on for over a year lots of hard rough miles on it and no problems, and i too have all other bmr stuff on my car minus the front end stuff.
i whould call probly be the best way ot get in touch than pming them
Eddie
Eddie
Glad to hear this early was about to do damn near the whole car in BMR I've been saving my pennies for a long time but I guess I'll buy from somebody else to bad they didn't jump on fixing your stuff. Good Luck
Moderator
Same here, post up what happens. I was going to do the whole car BMR. But now maybee not. I have the STB & SFC's was about to arder LCA's when I saw this post. I would call them & who you purchased the parts from. The vendor may have better luck than you. I can't believe they would not just send you a new one. Probably costs them $20.
They won't even swap you the broken one for a new one? WTF? Definitely call whoever you bought this from, they should have records of the transaction. I'm pretty sure you can get a copy of the receipt from them. Especially if they operate a website. I've heard a ton of good things about BMR, this is the first time I've seen them shaft somebody straight up. I hope this gets straightened out, and they help you out. Presuming the piece was installed right, then they should definitely be replacing it for you. From the facts we have so far, this is definitely looking poorly on BMR right now.
i'm now going to Spohn. i have the spohn torque arm and its BEEFY!
never again will BMR get my money. i've already called them and PM'd them... no responce for a long time (giving them time so they don't get another bad rap on this board) but enough was enough. i just don't want others to make the same mistake i did.
it killed my $350 drive shaft, pinion yoke on the 9 inch (don't know a cost but looks like a Moser one will be $124), and 28 for Moroso U-joint girdles.
all in all, i think this has been a very sour experiance in my mouth toward BMR
This is not the first time I have heard of BMR stuff breaking...
When I get money, I am going with Spohn stuff.
I am sure BMR will make everything ok, just get some information of the sale and try to just swap it with them.
-Todd
-Todd
-Todd
-Todd
i wouldn't trust another one anyway. if a 12.3 car can brake it while on street tires ON THE STREET, how would you feel with slicks dumping at 6600?
Originally Posted by ramairstyle00
the person i got it formcan't find where he bought it fom
I am running 12.6s in my cam and bolt ons setup with a 2.0 60ft. I might not be the best driver out there but keep in mind I am dynoing 380rwhp and added 373s to the equation. You could be beating my times with 40 less horsepower if not more. This is causing a lot of driving abuse to the car.
Awesome times . Not a hater, but you must understand that your are driving your car beyond its expected potentials and this is what could happen.
Please give us your 60 ft times and 1/8 time.
Good luck
Make sure and keep us updated, I'm also looking at BMR items over the winter..although I can understand their hesitance to help since you cannot show when or where it was bought....I'd sure hate to see one go though, right above my DUALS...
If they can't replace it because you don't have the bill, well that's one thing. I just don't want to be too quick to let BMR off the hook for this.
