good sway bars?
This is a good way to go if you are interested in performance handling. If it's a drag car, this is possibly not the way to go.
Now, we have ST bars, Addco bars, Hotchkis bars, and our own Hollow bars. The Addco's are too small in front/a little big to a lot too big in the rear (they have two different rears). The ST bar is a great front bar, but is heavy and the rear bar is too big. The Hotchkis bars are very nice and light, but expensive and the rear bar is still too large IMHO, though better than a solid 25. Which is why we made our own bars. I wanted hollow front and rears in order save weight, but also wanted to make a set with the diameters I wanted instead of compromising. My bars are 35 hollow w/6mm tubing in front, 22mm/4mm tubing in the rear and cost significanly less than Hotchkis and not a ton more than ST's. They are more because hollow bars are more involved to bend, but you also save about 24 lbs. on a set vs. a set of ST's and over 20 vs. an ST front, 1LE 21mm solid rear.
Spohn makes a good one for road racing/budget.
