Porsche brake questions and more
Originally Posted by roy
TEXTAR
JURID
MINTEX
Don't know if you can get the last three pads in the states or not.
JURID
MINTEX
Originally Posted by 69firebird
what about the calipers on the new CTS V? They are Brembo calipers, and are 4 pistons. The ones on my moms car are HUGE theyd be ncie on one of our cars, plus its a GM part how much can it cost
ed
ed
Oh by the way Rotora makes a bbk for our cars too, although I imagine it's the same caliper Stoptech uses and like someone else said they probably source the design from Brembo.
![](http://www.rotora.com/online-store/scstore/HTML/images/products/popup/popup_kits.gif)
so is the front or rear porsche brake caliper used on the rear of the fbody? ALSO is there a certin year of porsche that u use for the caliper? its the rear caliper i think but not 100%. pm me the reply please
The rear brakes on a Fbody are a floating caliper design. This design allows for caliper movement for C-clip axles when the axle shaft moves slightly in and out of the axle housing. The Porsche calipers are a fixed caliper design. When these fixed calipers are put on a c-clipped axle , the movement of the axle shaft going in and out ever so slightly will cause the rotor to push in the pistons of the fixed caliper. This is very predominant when coming out of a tight corner and then standing on the brakes to slow down. Which results in a long brake pedal.
I think I might understand the "long pedal" ur talking bout but what axels do u use to eliminate that? or should I just put c5s on the rear & be done with it. I'm not going 2 be running tight corners but maybe hit the track a lot this summer
#32
You should be fine with normal driving and 1/4 mile, but you will see the long pedal on roadcoures and slalom events.
You have a few options
1. Live with it.
2. get a aftermarket rear end with presson bearings on the axle shafts
3. Modify your current axle.
1. Live with it.
