Shock question
Old Jan 11, 2005 | 09:18 PM
LS1_Unleashed's Avatar
Default Shock question
I have an '00 SS and its my daily driver. It has around 60,000 miles on it, and i wanna improve the ride quality. What are the best/cheapest direct replacement shocks and where can I find them?
Old Jan 11, 2005 | 09:30 PM
ZaneO's Avatar
The minimum replacements are Bilstein HDs. You can get them for around $320 from Sam Strano at www.stranoparts.com
Old Jan 13, 2005 | 08:17 PM
96blackz28's Avatar
agreed
Old Jan 15, 2005 | 01:53 PM
elite22xl's Avatar
i was looking to do the same with my 02 ws6. also was thinking about getting 1inch lowering springs from BMR. i understand that that is a decent setup to lower the car a little. will the ride be the same (just aprox. 1 inch lower)if i just do the "minimum" shocks and bmr springs, or will it handle like crap without doing full out suspension upgades?
Old Jan 15, 2005 | 04:12 PM
ZaneO's Avatar
Bilstein HD shocks are valved, damped, etc. for stock springs. Springs with higher rates and lower travel will be much more harsh on shocks not meant to handle those factors.
The Bilsteins will be better than stock, but still not optimum. The better options would be revalved Bilsteins or Koni SA shocks.
Old Jan 15, 2005 | 04:33 PM
elite22xl's Avatar
whats the better option in your opinion, and where should i look to get them from?
Old Jan 15, 2005 | 05:59 PM
ZaneO's Avatar
Your best option would be the Koni SA. You need to call Sam Strano and discuss your needs with him. He'll set you up with exactly what you need, and he has some great prices.
Old Jan 16, 2005 | 10:08 AM
elite22xl's Avatar
what would happen if i just put in the bilstein hds
Old Jan 16, 2005 | 10:16 AM
mitchntx's Avatar
Nothing ... it would be fine.
Like Zane said above, the Bilstein HDs are not OPTIMUM for the rate, travel and height of an aftermarket lowering spring.
But to attain the limits of this shock, you will probably need to install R compound tires and be running at near the limits of the car's suspension on a closed road course.
If that is your application, by all means, a revalved shock should be on your car.
If you drive it to school/work, hit an occasional on-ramp at higher than posted speeds ... the HD will be fine. Under those conditions, your tires or crap on teh road will limit your handling way before the shock will find it's limits ...
Old Jan 16, 2005 | 10:42 AM
elite22xl's Avatar
when you say find its limits, do you mean like max out the shock?
Old Jan 16, 2005 | 12:08 PM
mitchntx's Avatar
Go beyond it's abilities to do the job it's supposed to perform, not bottom it out or over extend it ... that could happen with any shock if it's not sized properly.
Old Jan 16, 2005 | 12:20 PM
elite22xl's Avatar
so then what exactly would happen, the ride would be good for a little while then crap out or?
Old Jan 16, 2005 | 05:02 PM
mitchntx's Avatar
It's more of a per incident thing than a long term degredation ... although taxing a shock does have some long term affects.
Shock would probably lose it's ability to dampen properly. After it cools, it might again work as normal or it might blow a seal and begin leaking.
Lots of things can happen ...
Old Jan 16, 2005 | 05:46 PM
elite22xl's Avatar
how long do i have on the bilsteins before something goes wrong if i put them on?
Old Jan 16, 2005 | 05:53 PM
mitchntx's Avatar
I put mine on in '99, using Eibach Pros and G2s ... still seem to be fine after 80K miles
Old Jan 16, 2005 | 06:11 PM
elite22xl's Avatar
who makes the g2s?
Old Jan 16, 2005 | 10:26 PM
ZaneO's Avatar
who makes the g2s?
G2
www.lgmotorsports.com
Old Jan 16, 2005 | 11:46 PM
badjuju342's Avatar
Deranged Rat Fink
The Konis also have a lifetime warranty.
Old Jan 17, 2005 | 01:45 AM
Racehead's Avatar
I say go with the HD's. The price is pretty good and if you need something more later on you can have them revalved or step up to a Koni SA or DA. The HD's are a pretty good all around shock IMO
Old Jan 17, 2005 | 07:02 AM
mitchntx's Avatar
Ever tried to use that warranty?
It's nice to have, but you remove your shocks and send them in for a rebuild. And the backlog is rarely less than 30 days ...
