Front tires wanting to follow the road...
my car has a pretty annoying problem with wanting to follow the road. sometimes it gets pretty bad as to almost put me in the lane next to me. i understand that the 9" wide tires in the front are what are causing it. also my car is lowered about 1 1/2". what im trying to find out is can i get some kind of alignment that will help with this problem. or anything else i can do to take care of this problem. thanks for the space ls1tech.
If you think it's bad in an F-body try a Z4 with the runflat tires. Those thing tramline all over the place. They twitch like a crackhead on unsmooth surfaces. My Formula with 245/50/16's up front don't follow the road...maybe you should try less wide tires?
what would i change in the alignment. i dont really know much about this. also i think i have to go with 275 tires because of the 9" wheels. thanks for the replies.
bring in your camber so it's negitive and bring in you toe.. this will wear out the insides of your tires more and faster than the outside but it works.. i'll check my alignment out tomorrow and post my actuals so you can get some numbers.
Originally Posted by abadss
mine does the same thing, and my camber is the oppostie from what was suggested above. they seem to be wearing on the outside edges. so reversing it may be a good idea.
