STB? Worthwhile mod or no?
Old Mar 14, 2005 | 10:32 PM
joblo1978's Avatar
Default STB? Worthwhile mod or no?
I've heard many things about this, is this just an appearance mod or is there actually something to be gained from it under all kinds of driving?
Old Mar 14, 2005 | 11:44 PM
12stones's Avatar
I'd go for it, and get some sub frame connecters too!
Old Mar 15, 2005 | 01:35 AM
2MuchRiceMakesMeSick's Avatar
Good for cornering but not something you want in drag. Mainly due to weight.
Old Mar 15, 2005 | 01:42 AM
1 BLOWN V8's Avatar
Weight on a STB is only 5LBS on a 2 point system.
Old Mar 15, 2005 | 07:35 AM
joblo1978's Avatar
I ordered some friday and am waiting for them. I'm really trying to turn my TA into a corner carver.
Old Mar 15, 2005 | 08:33 AM
2w0s060's Avatar
I got the UMI Performance Chrome Moly one and it weighed only 4.5 lbs, like you said weight isnt to much of a concern
Old Mar 15, 2005 | 01:19 PM
jimmyblue's Avatar
Moderator
My 'vert had an annoying "woggle woggle" when thrown around
corners, which the Hotchkiss STB made go away. So it does
do something. Some people seem to not think so but this is
my experience.
Old Mar 15, 2005 | 03:18 PM
rtr2001ss's Avatar
I've got the Hotchkis STB, ran 12.8 with it on. It helps with cornering, and made an annoying dash rattle go away after I put it on.
Old Mar 16, 2005 | 03:05 AM
Its only 5 lbs... Try telling that to guys that drag race. These people take EVERYTHING they can for weight reduction. Especially on the nose of the car.
Only disadvantage would be weight and it gets in the way (or you have to remove it) when you go to work on your engine
Old Mar 16, 2005 | 12:04 PM
Red Orange 96's Avatar
I have a BMR two point brace and it tightened up the steering alot.
This was on a completely stock ta though. Plus it is under $100, last
time I checked.
Old Mar 16, 2005 | 05:49 PM
Shuck's Avatar
I did it because is seems to help out with cornering a little, and they are cheap so not really a big loss.
Old Mar 16, 2005 | 06:29 PM
Andros's Avatar
It's worth it imo, the car corners better at higher MPH than it used too from what I do, sometimes when I'm lazy to use the brakes.
Old Mar 16, 2005 | 06:32 PM
joblo1978's Avatar
Maybe I'll get one then, just to round out all the other suspension mods. I can't wait until my SFC's get here first though.
Old Mar 16, 2005 | 06:35 PM
rotwiler's Avatar
I have a BMR STB and added the STB about a month after the boxed diamond SFC's. When I bought my car I hated the way it wandered around the highway, had alignment checked and was good. I did the SFC's and wandering was better, so for under $100 I decided to do the STB and it improved the wadering even more. Now it drives like I expected it to, so I highly recommend the STB and the SFC's. With the BMR it touched my tube from the A4, so I put a black foam cover over the tube to stop vibration.
Old Mar 16, 2005 | 07:16 PM
jimmyblue's Avatar
Moderator
One thing that made me go for the Hotchkiss, is its
mounting hardware; you can take the center bar out
(2 cross-bolts) to work on the engine and leave the
strut-attached plates in place. Plus it sets back kinda
out-of-your-face compared to others.
Old Mar 16, 2005 | 07:56 PM
Squirrelmaster's Avatar
Same here. No more squeeks from my dash pad . And you'll love the subframe connectors .
Tom
Old Mar 16, 2005 | 08:29 PM
Another_User's Avatar
I have the UMI Performance STB. Incredibly noticable difference in understeer. The car steers and corners like a much different car.
Old Mar 16, 2005 | 10:03 PM
fasteddyss's Avatar
I was on the fence about these for quite a while. I made my decsion soon after loking at a new Motor Trend last fall. Both the Cadilac CTS-V and the new GTO have them from the factory.
Old Mar 16, 2005 | 10:15 PM
MadIceV8's Avatar
Customizing Director
Ya same reason I decided to go with one of those also. I felt I noticed a difference with the front end being a little tighter.
Old Mar 17, 2005 | 09:31 PM
Mike98WS6's Avatar
I'm not sure if it does much. But it does look nice under the hood.
