Larger front rotors... with stock calipers? Possible?
Looking to upgrade front rotor size. However, I do not feel like spending $250 on brackets plus the $200 for the C5 calipers and then rotors. Is there a way to upgrade the rotor size and keep our fron f-body calipers. I ask b.c on my GTP we have a braket that is very cheap available to use larger rotors along with LS1 calipers or retain the stock calipers.
TIA
Brandon
TIA
Brandon
LG bracket? Sorry still a little new to the LS1 aftermarket. Is that the $200+ bracket? Like I said... it blew my mind when I can get a similar bracket for my GTP(which I do have on it with 12.?" rotors) for something in the neighborhood of $50 for the pair.
The GTP brackets are OEM GM parts (Oldsmobile Intrigue) and there is no factory equivalent for the F-bodies. Your only bet is an aftermarket retrofit bracket like the LG bracket (see LG Motorsports in the sponsor list), which is a high quality piece made of CNC'ed aluminum. Since you can reuse the stock calipers and pads, the $250 you spend on the brackets plus a pair of C5 rotors is actually a relatively inexpensive way to get a 13" rotor up front, while retaining factory hardware.
Originally Posted by SVC707
I used the LG kit and an aluminum spray paint color
Thanks
Originally Posted by jargan04
Yes order the LG C5 adapter brackets. They are $250 plus 2 front vette rotors. You can get any front C5 rotor you want and you can keep all the stock stuff. I have the brackets and love them.
Here it is on my car.
![](http://www.c-computers.com/c5-upgrade/after2.JPG)
