Which Brakes Better?
Old Apr 7, 2005 | 08:56 PM
CamaroSS's Avatar
Default Which Brakes Better?
An F-bod such as mine with upgraded pads and rotors, or a car with C5 Rotors and Calipers?
Also how many pistons are in the stock front and rear calipers? Floating?
Thanks
~Someone who knows NOTHING about brakes, Kevin.
Old Apr 7, 2005 | 10:41 PM
felton316's Avatar
Probably who ever has the better pad and better tires. The C5 and F-body caliper are identical except that the f-body caliper is gravity cast, while the C5 is pressure cast. The pads will make a huge difference, but you can have the best pads in the world, but if you have shitty tires, it will do you no good.
Old Apr 7, 2005 | 10:45 PM
BrandonSS's Avatar
But the C5 has the physics advantage with the larger rotor. Better form of leverage on the caliper being further away from the axis.
Forgive me, I have a upper respritory infection with Vertigo.. so my technical terms are absent due to the drugs
Old Apr 7, 2005 | 10:46 PM
psykoTA's Avatar
Everything being equal, pads, tires, car weight, etc. The car with the C5 rotors should stop sooner, due to them being an inch larger.
Old Apr 7, 2005 | 11:46 PM
BrandonSS's Avatar
YUp.. I just said that.
Old Apr 8, 2005 | 12:11 AM
psykoTA's Avatar
I was typing the response, clicked submit, and there you are, beat me by a min.
Old Apr 8, 2005 | 12:23 AM
BrandonSS's Avatar
was kidding my bad on the lack of a properly placed smilie in that response!
Old Apr 8, 2005 | 01:34 AM
DONAIMIAN's Avatar
Go out in your car right now take it to about 60, and the stop as fast as you can. If ABS comes on your tires are your limiting factor for stoping distance.
Old Apr 8, 2005 | 05:13 PM
psykoTA's Avatar
And rotor size has nothing to do with it? If thats what you mean, I disagree.
Old Apr 8, 2005 | 07:53 PM
CamaroSS's Avatar
Well I can lock the brakes up at over 100mph, and com to a stop pretty darn quick! How quick? I am not sure.....
They are EBC Cross Drilled and Dimpled Rotors with EBC Green Stuff pads......very nice, love the sound to!! Now the car sounds menacing accelerating and decelerating.
Old Apr 8, 2005 | 08:11 PM
Racehead's Avatar
Dis-agree if you want, but it's true. If the stock brake size will lock the tires up how will more braking force stop you sooner ? By locking the already locked up tires more ? Think about it. There IS a reason to upgrade your brakes, but producing more braking force is NOT the reason. Repeatability is the reason. It's the 2nd, 3rd, 4th consecutive stops that your trying to improve, not the 1st one.
Old Apr 8, 2005 | 08:24 PM
CamaroSS's Avatar
Very good point. I am very curious to see how well the car can brake wiht some Nitto 555 DRII on.....:yup: See if they lock up then....
Old Apr 8, 2005 | 08:34 PM
psykoTA's Avatar
I am going to think about that
Old Apr 9, 2005 | 03:26 PM
DONAIMIAN's Avatar
No thats not what I meant, I mean its pointless to spend money on brakes with more bite, if the ones you already have, has the power to lock the tires.
Old Apr 9, 2005 | 03:28 PM
DONAIMIAN's Avatar
whoops beat me to it.
Old Apr 9, 2005 | 11:30 PM
felton316's Avatar
The RII's were a damn good upgrade for decreasing my braking distance, but I bet any sticky tire would be better than a regular radial.
Old Apr 10, 2005 | 12:08 AM
Deamon2002's Avatar
You can always just attach a chain to your frame and to a couple of center (cinder?) blocks and when you need to stop just pitch them out the window. LOL!
Old Apr 10, 2005 | 12:21 AM
jargan04's Avatar
I have done the C5 front brake conversion and there was a big difference in stoping power with the stock pads. The larger rotor made a huge difference. Get C5 rotors, LG C5 adapter brackets and new pads such as Hawk or EBC. That combo will make you stop.
Old Apr 10, 2005 | 06:19 PM
psykoTA's Avatar
Thats my current plan as well.
Old Apr 10, 2005 | 09:09 PM
Steve in Seattle's Avatar
C5 kit has several advantages over the LS1:
1) The caliper is pressure-cast and more consistant density-wise.
2) The caliper fins which dissipate heat and add strength to the caliper span the entire bridge, not just the rear of the caliper as in the LS1 design.
3) The C5 caliper has slightly smaller pistons, meaning the total force (which can get excessive after lock-up) is less.
All three points lead to less caliper spread in the C5 caliper. The C5 also has stainless-steel pistons available for rebuilds... the LS1 calipers do not.
4) The C5 rotors have directional vanes in the rotors leading to more efficient cooling, with less chance of heat soak / pad fade.
5) The C5 rotors are 1" larger and several grams heavier... leading to more heat capasity (can absorb the same amount of heat but retain a cooler temperture). This slows the temperture spikes and lowers the max temp reached from braking... again, less chance of heat soak / pad fade.
6) C5 rotors are cheap... I picked up a set from GMPartsDirect.com for $50.
As you see the C5 system really is better than the LS1 design... but it also has some draw-backs:
1) The 1997+ spare tire (aka LS1 spare) does not work with the C5 kit.
(Although there are rumors of a spacer kit working with the C5... I've yet to confirm it... typically you need to carry a 17" spare meaning there's no way to fit it in the trunk location... although a battery or nitrous bottle will fit in there nicely. Others just use AAA and take their chances.
2) Increased rotational, unsprung mass of the C5 kit increases the force needed to accelerate, brake, and turn the wheel/vehicle.
(Road Racers who make repeated stops and worry about pad fade are always willing to sacrifice weight here though... for daily driving its probably not nessesary).
