relocation brackets?
Old Apr 14, 2005 | 11:37 PM
USMARINE1108's Avatar
Default relocation brackets?
So I'm in the market for some relocation brackets, but I'm trying to decide between BMR's and Sophin. Any suggestions? Oh yea, I'm looking for some LCA's too. Any suggestions? Thanks.
Old Apr 15, 2005 | 07:49 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
Dimensionally,They're the same.Spohn are bare metal welds-in.BMR are coated bolt-ins.There are many threads debating/discussing weld-in vs. bolt-in.Do a relocation bracket search.
Old Apr 15, 2005 | 08:23 AM
UMI Performance's Avatar
http://www.umiperformance.com/Search...?CategoryID=37
Old Apr 15, 2005 | 08:46 AM
Fulton 1's Avatar
IMO, the bolt-ins are the better choice because there's no way (assuming they're built correctly) to screw up the installation as there is with weld-ins. With a little grinding, the bolt-ins can also be welded for additional strength.
Old Apr 15, 2005 | 09:12 AM
gator's 99TA's Avatar
i LOVE my spohn relcoation brackets. i got mine 3 years ago when they were huge. now they are smaller. dont know why.
Old Apr 15, 2005 | 09:21 AM
chupr0kabra's Avatar
I got the BMR bolt-ins and they were a breeze to install. Took me all of 30 minutes, including the time to cut the e-brake cable brackets.
-Mike
Old Apr 16, 2005 | 01:13 PM
JGA's Avatar
JGA
Hi
The only real difference I can see is that the Spohn moves the lower mounting holes forward in an arch, meaning you can maintain the same pinion angle using the lower mouting points on a car with stock ride height and non adjustable control arms. If you lower the car, or use adjustable control arms then it realy makes no difference.
JA
Old Apr 16, 2005 | 06:13 PM
lt1hatesme's Avatar
is your car lowered? if not you really wont need the brackets.
and i would go with spohn lca's, i have them and they're great.
