Doing My First Brake Job, Help???
I'm doing my first brake job, all Im doing is turning the rotors and puting new pads on. I can rebuild the whole car but when it comes to brakes i've never touched. My questions are basically how do i take the rotors off, how do i remove and install new pads and is there any adjusting i need to do to system (brakes) for new pads. This is for the front only the rotors are pretty warped not real bad but enough to drive u crazy when u are stopping.
It is that easy....I just didn't know if the LS-1 cars brakes changed formt the lt-1 cars....I would still buy the book because it will haev alot of useful info in there if you ever decide to rebuild the motor just anyting you have questions on.
Copy & Paste Moderator
Originally Posted by XtinctHawk02
http://www.installuniversity.com/ins...ds_mwarren.htm
You should never have to add any brake fulid or take any away. Your brake reservoir goes down because it is getting pumped out into the calipers, when you push the caliper pistons back in that will fill up the reservior again. If you have happened to add brake fluid because you thought it was low then you can just loosen a bleeder screw on any of the calipers. This will be a two man operation. One will have to push down the brake, then the other will open the bleeder screw, while keeping the pedal down the person will close the bleeder screw and then you can let up on the pedal. Not doing this will cause air to get into the brake lines.
Originally Posted by mrt5677
When doing the brakes, how do you remove some of the brake fluid from the reservoir?
