Brakes Locking Up
Very rarely would a ABS system cause this w/o a ABS light on. If it where to blame it would prolly not be drivable, seen that B-4. Never seen a master cause them to hang up that hard. Only the overfilled master or misadjusted pedal actuator rod causing the brakes to drag slightly.
When you crack a bleeder w/ a colapsed hose, it will spay out. Not gravity bleed, it will be obvious there was alot of pressure there. A hose failure/caliper failure is far more common in this area then anything else.
Thanks for the info, that's some good tech.
