Suspension vs Performance
I was thinking on investing on suspension before adding more power.
TQ Arm
Shocks
Springs
LCAs
Relocation Brackets for LCAs
Drag Rear Swaybar
New bushings all around
Missing something?
I will be buying this items two by two each month, in which order should i buy them?
TIA
Sorry, anyway.....Subframe, Lower Control Arms (rear), Torque Arm, Sway Bar (Rear), Panhard Rod, Tunnel Brace, Upper and Lower Control Arms (front), K-member.
This is a good list on how to go in order.....or at least to me. I will be going that way too. BTW Torque Arm = $$$$$ U/L Control Arms = $$$$$ and last but most expensive, K-member = $$$$$
About springs and shocks, is there any spring for a drag application that lowers the car?
my car is a lot higher than other stock cars around, i don't know why...
Stick to stock height for performance benefit on weight transfer.
Now for road racing, lower is better. You can get a 2 inch drop, and corner better, and look awesome.
I say get the QA1a, lower the front a bit, and fill the rest in with an ET Street 28" :yup: If you add a larger wheel with a lower profile in the rear, then you will dramatically change it's cornering characteristics. If your sidewall tire profile gets very small, then the tire will have very little lateral stress to the point that it will cause you to drift in sharp corners at high speed.
If you are SERIOUS about drag racing, look at the upgraded versions to what I listed, some torque arms only support a certain amount...etc.
~Kevin
I may have to try that. Problem with my car right now is wheel hop and lack of traction, i dont know why, but when i removed the front swaybar wheel hop was a lot worse.
Then a friend with a stock 98 parked right next to my car and my car was a lot higher than his, both stock suspension.
For the LCA's, should I get the spherical rod end, or poly bushings on both ends?
I'd have to say LCA, Panhard Rod, Subframes, TQ Arm, good shocks on all four corners with matching spring rates to your application, sway bars (if you want to handle), then do you're Upper/Lower A-arms and K-member.
The steel stamped stock LCAs are meant to flex and eat up bumps. That's great for a car that's daily driven like a stocker but it isn't the best for performance, straight or twisties. Not only are they supposed to help the rear stay square and go up and down, but they also need to let it twist on the driveshaft axis (in other words, say the right rear goes over a bump but the left rear doesn't). The structure of the stock LCAs and their rubber bushings allow for this to happen. Aftermarket LCAs are a bit better than that with the polybusings, and rod ended ones, though noisy and wear more, do it even better. It's all about letting the rear stay in contact with the surface, yet minimizing bump travel, and putting it back to the pavement quicker and harder.
Reason I said PHR 2nd is that this helps locate the rear left to right. Very important! Like the lca, the stocker phr flexes some too to eat up the "felt" road noise and vibration, but this allows the rear to slap back and forth (though slight it still happens). A good aftermarket phr will keep this from happening, and upsetting the handeling of the car while cornering, or even when you're trying to plant and go straight. Basically a NASCAR car uses this to adjust track and wedge to get the weight transfered around for handeling.
Subframes help stiffen the chassis, I know duh! That will help with weight transfer and making you put a more even contact patch to each rear tire. Makes sense.
TQ Arm will help set pinion angles and keep the rear planted better. This is basically what drives the car. It's the 3rd link in the "semi" 3 link suspension. The rear end pushes on it and the LCAs to move the car, but the TQ Arm gets most of the force, which you want. I remember reading about truck arm suspensions that are used on NASCAR chassis and they are long (probably about 3~5' as a rough guess) and where they are located is to the middle of the chassis, getting real close to where the bellhousing is. In other words, the more force you put at the center of the car to drive it forward the better off you are. Also, a TQ Arm will better plant the rear tires from weight transfer on launch and on heavy breaking.
Now that you have better weight transfer, make sure you get shocks that will more specifically control it better. Shocks are key as they and your tire are what really keep the rubber to the road the most. All those great components up there ^, do you no good if the compression is to loose and the rebound to slow. Besides, when you launch, you don't want those front wheels bouncing on the shocks going down the track for 300 feet.
Then hit you're sway bars, A Arms, K-member and make sure you get it all ALLIGNED!!!! Yes that last tip will cost some money, but it's well worth it as you definately want it all to work in perfect harmony!
GL, have fun.
