Lost Break Pressure
Old Jul 21, 2005 | 09:57 AM
hambone138's Avatar
Post Lost Brake Pressure
Yeah I recently got in a accident because someone cut me off on the highway, spun out blew rear right wheel. Changed wheel, lost break pressure and pumps when de-pressed, RR sqeaks and sounds like its grinding, but not constant (you know the faster I move the more sqeaks). I am about to bleed the system but I do not think that will fix it, am I right or do I need to look at somthing else?
corrected spelling for ya in the title
-stang killer
Old Jul 21, 2005 | 10:16 AM
pimpmaro's Avatar
Well, I'd start by checking all your brake lines for leaks or damage. Specifically the RR area. Check the caliper as well for leaks. As far as the grinding sound, you'll probably have to pull the rotor, because I'd first check the drum brakes (e-brake) on that wheel for the dragging sound. Let us know.
Old Jul 21, 2005 | 11:23 AM
mitchntx's Avatar
Either a bent axle or bent rotor.
The wobble is knocking the pad into the caliper piston and moving the piston back into the caliper.
Old Jul 21, 2005 | 12:26 PM
pimpmaro's Avatar
Ok ok, so I was just filling space and time until someone who actually knows what they're talking about came along.
Old Jul 21, 2005 | 12:34 PM
hambone138's Avatar
maybe im stupid but i can see how that can effect the sound but i cant see how it can affect the brake pressure.
Old Jul 22, 2005 | 02:02 AM
pimpmaro's Avatar
I believe mitch is referring to the grinding and squeaking. If you have no brake pressure you should still inspect the ENTIRE system for damage and ensure it's reliability. Have a helper watching for leaks while you press the brakes... that helps to spot a leak. Mitch is a smart smart man... I don't doubt him that that is the most probable cause of the rear noises.
Old Jul 22, 2005 | 04:13 AM
mitchntx's Avatar
Piston knock back creates a space between the pad and rotor face. The only way to take up this space is to push fluid through the caliper. You do that by stroking the pedal.
The "pulsing" you are feeling is the wobble against the pad.
When sitting still, do you have a firm pedal?
Old Jul 22, 2005 | 08:05 AM
hambone138's Avatar
Yup i will never doubt you again. yeah it was bent about 1/4 to a 1/2 in. im suprprised i made it home after the accident. thanks for the tip got a new axel comming and hopefully get the car running again today. was thinking about changing the gears since i will be in there but i think im gonna have to wait. THANKS GUYS!
Old Jul 22, 2005 | 08:31 AM
mitchntx's Avatar
Glad you found the problem. Did only your rear wheel contact the curb?
If the front hit it as well, you should check the front hub assy and the front knuckle.
A competent alignment shop should be able to tell this easily enough.
