Upper Panhard Bar
Do yourself a favor and just pick up a new bolt from the dealer. Any halfway respectable parts guy will be able to pull up an exploded view of the rear suspension on the computer and you guys can easily locate the bolt you need.
Also, do not run without the upper PHR and don't just get some bolt from the hardware store. As pimpmaro noted above, the upper PHR is a structural support for your PHR so if you're running without it you simply don't understand how the suspension works. Also, most of GM's suspension bolts are Prop Class 10.9 (equivalent to SAE grade 8) so you can't just pick up any bolt of the same size and expect it to be suitable. Finally, again as noted above, the PHR bolt is stepped and so a standard bolt wouldn't work well anyway.
Dealership was like 3$ a piece. Junkyard would be like 2$ (but I can just get one)
Dealership was like 3$ a piece. Junkyard would be like 2$ (but I can just get one)You may be able to find it cheaper there but for crying out loud don't drive around without that bolt in the PHB.
__________________
to Fulton1
