3rd gen rear shock
The 3rd Gen Koni's must be removed from the vehicle in order to re-adjust the shock. They're also a 4 position adjustable. The 4th gen Koni's can be adjusted on car.
Originally Posted by Viper
Sam Strano recommends 3rd gen Bilsteins for the rear with Eibach's; the valving on the shock is quite different than the 4th gen Bilstein, and it can handle the spring rate much better.
Not because it's cheaper.
Originally Posted by Zepher
any idea why the valving is different?
LS1TECH Sponsor
Becaue there are springs rate differences and leverage arms differences between the two cars, the axle in a 4th gen is longer than a 3rd gens. Simple to say "they are the same", but there are subtle differences......
Why do I sometimes use 3rd gen rears on a 4th gen? There is no one reason. Price is one, valvling is another. A combination, but there have been times I've used a 4th gen shocks on 3rd gens too...
__________________
So if I am going to use Bilstein HD's on my stock springs would I be getting more bang for my buck with the 3rd gen rears? or Would this only be beneficial with aftermarket springs?
LS1TECH Sponsor
Want the short answer? Each situation is different. I use 4th gen HD's when 4th gen Hd's are used in front. I tend to use 3rd gen HD's when we use Revalves to better match the more aggresive valving wanted for lowering springs. I will use either with Koni's, just depends on what the customer wants. Since they adjust you have wiggle room.
__________________
