Who has actually broken their tailshaft?
I can tell that it was under hard braking that you broke it based on the down ward shearing of the trans tail housing. Do you experence a bit of wheel hop under hard braking? The shock load when that happens leads to this type of failure. The factory bracket is stamped steel that does not distribure the loads evenly to the mounting bolts, major problem. That mount in the picture was a early experiment dealing with the same issue, finally went with A BMR so that I could adjust the axel center with the lower body height (nice feature) took care of my problem, would highly recommend.
I believe the breakage is more commonly from the
driveshaft whipping (stock steel 'shaft reused after
gear swaps, especially) than the TA load.
I like the look of that clamshell and always wanted
to see somebody make something like that, but
that mounted sandwich style between the trans
and trans tail mount to get the stout base but
use the trans mass to soak up the vibration. To
have it strap the tailhousing too, is fine, but making
the torque-return path go right to the tail mount
is even better in my view.
Something like this would be the answer for all us
weekend warrior, still want a smooth ride types
who can't stand the downside of the crossmember
mounts.
mounts.
third pull on the dyno mine took a crap on me. I still have the steel drive shaft as well as a prothane tranny mount and motor mounts. I had a vibe at 55mph and higher it got worse with the speed but i thought it was just the stiff mounts. I broke my tail shaft i dont think it was all the TQ arm but a mixture of that and the steel shaft. i replaced the tail shaft housing and put the stock mount back on no viberations I think imma try a alum drive shaft and that BMR relocated TQ arm mount abouve
#34
Sorry - my car is road-race only. In fact, I have a race version of the arm. Difference is that my tunnel mount ties directly into my cage, instead of bolting to the floor of the car.
As far as its effectiveness, it's a very good modification. I get very predictable results with it, now that it's properly setup. The brake hop is almost non-existant (though I'm not sure anything is completely eliminate it). At the end of the day, I'm usually in the top 3 and fighting for position. That's good enough for me!
#38
With the body mounted torque arm do you get harmonics or more vibration through the interior of the car?
I just got done fighting with a poly trans mount that was causing horrendous harmonics.
#39
