PHR questions
If the tires are rubbing on one side more than the other, just lengthen or shorten the PHR to help balance it out. Once both sides are rubbing equally, you will need to hammer down the high spots. Black paint over the exposed metal and drive it for a few days. Then check for shiny metal spots.
If you do a search on this forum you will find a lot of info on fitting 315's.
Jack up the rear of the car and find out what it's rubbing on then we can figure out a fix.
This it what mine looks like:
Pic
I would not recommend it, instead you can trim the factory bumpstop a little on the sides. Like this:
