What Torque Arm Should I Get?
Originally Posted by felton316
What are your plans?
I meant use of the car..... all out open track car, drag racer, auto-x, etc.....
Originally Posted by JAMES RODRIGUEZ
Spohn tranny mounted.
Hi
I had bad luck with the Spohn tranny mount arm. It does not clear the factory exhaust at the front. They claim it is a bolt in with no welding or fabrication required. That is not my experience. Check around the forum and you will find others with fit issues. I am replacing it with a BMR unit.
JA
JA
Where exactly did it not clear? I can't see where there would be any contact with the exhaust. The T/A runs along side the tranny, the exhaust should be going under the tranny.
felton316
Have a look at this link. There are a few photos. The Y pipe actually does come directly under the torqure arm at the front.
https://ls1tech.com/forums/showthrea...relocation+kit
This guy had to use a BMR torque arm relocation kit and notch the Y pipe to get it to fit. Also, he was able to get the tunel brace on with the relocation kit, but it will not fit without it.
Thanks JA
Thanks JA
RrCoX22
I believe the greatest problem with the tranny mount torque arm is that it may break the tail shaft on your transmission. There are a few photos around on this forum so have a look. I assume it is only a problem if you have lots of HP, gears and tires.
With the tranny mount you will loose no ground clearance. With the BMR reclocation brace I believe you will loose about 3/4" to 1". I beleive with the Yank a little less.
With a tunnel mount torque arm it depends on your exhaust. With a stock Y pipe you will not loose too much. But if you have long tubes, then you have to get the design with additional clearance in the tunnel support. Not too bad on a car with stock hight, but may be a problem on a lowered car for street driving.
JA
JA
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
A Spohn TA doesn't come close to hitting the exhaust on a stock height, stock y pipe exhaust. Mine has tons of clearance.
Also, the breaking the transmission tail shaft seems to be more an opinion than fact for street / strip cars.
Check with Sam Strano (both a racer and a sponsor here) about tranny mounted TA's. www.stranoparts.com
beaSSt
Hi, thanks for the input. It's a bit of a puzzle as my car is stock ride hight and I am not making out very well with my torque arm. I don't suppose you have any under view photos of you car, or perhaps you can get one next time you do work on it. It would help me out. Thanks
JA
JA
