Hot Rotors
So what would cause this? Should I bleed the brakes? What would be possible reasons for this happening?
Thanks fellas!
I would jack the rear in the air, take the rear wheels off, and have someone pump the pedal to ensure the rear pads are engaging......
Because ever since I took off my rotors to change 2 broken lug studs (one on each rear wheel) it felt weird braking-wise. Also, I can "feel" that the front brakes are doing most of the work. Also, braking performance at fast speeds is horrible (shaking steering wheel, vibrations) I don't know if it's because my rotors are warped or why else this would be.
