C5 brakes to 98+ f-body: direct bolt on?
Are the Corvette C5 brakes (rotors & calipers) a direct bolt onto an LS1 f-body? Just wondering because the new C6 Z06 6 caliper 14" front & 4 caliper 13" rear brakes bolt directly onto a C5 with no modification at all. So if the C5 stock brakes fit an LS1 f-body, then I think it'd be pretty safe to assume the C6 Z06 brakes will swap onto an f-body with no modifications
Originally Posted by Frosty
Are the C5 brakes THAT much better than the Fbody's?
LG Bracket, Polished Fbody Calipers, LG DBA rotors on my TA.
Originally Posted by ChevyChad
I don't think you read my innitial post fully. This would be used for C6 Z06 brakes purposes on an f-body...
I did. I was asking a different but somewhat related question based on Louis' response.
I wonder if the C6 Z06 setup is still a floating caliper since it's a 6-piston front/4-piston rear design??.... with pistons on each side of the rotor, it could be a fixed caliper setup. The regular C5 Z06 was only 2-piston front/4-piston back, and all pistons on the same side, right?
Originally Posted by jargan04
If someone was able to make them fit an fbody. You still have to deal with the parking brake.
I thought about that some and I came up with the solution... I'm going to carry a few bricks and a board to keep the car from rolling
I bet those brakes would look good on an Fbody
The C5 uses larger bolts than the F-body. So, (assuming the C6 parts are a direct bolt on for C5 stuff) you'd want a C5 conversion that is designed for the C5 PAB and not the F-body version (the F-body version will have holes that are too small). Just something to consider.
