uneven suspension
Old Oct 10, 2005 | 12:15 PM
kyles2000z's Avatar
Default uneven suspension
ever since i've had my car. the front has sat higher than the rear, and the passenger side sits higher than the driver's side. this was noticable before and after i installed lowering springs that lowered it 1 3/4". today i decided to measure from the bottom of the fender to the ground just to see how off they were. here's what i got....
driver's front= 25.5 "
driver's rear= 25"
pass. front= 26.5"
pass. rear= 25.5"
so the driver side is roughly an inch lower than the pass. side, and the front is roughly an inch higher than the rear.
what't the problem here, and how can i fix it...it's been diving me CRAZY when i look at it! i've heard of the metal and rubber spacers....would this be the best way to go?
Old Oct 10, 2005 | 11:17 PM
kyles2000z's Avatar
Old Oct 11, 2005 | 01:36 PM
01 Red WS6's Avatar
Join the croud. All of us have this problem. Mine has gotten worse and now is about 3/4" lower on the passanger side. It used to only be a 1/4" but now it has gotten bad. If I knew how to fix it I would
Old Oct 11, 2005 | 02:13 PM
The Golden One's Avatar
Yep Ive got the same problem! I even spoke with 01 Red WS6 through pms about this. It sucks! There has to be a way to fix it. Maybe coilovers!!!
Old Oct 11, 2005 | 05:08 PM
DONAIMIAN's Avatar
thats why im looking to put coilovers on my car.
Old Oct 11, 2005 | 06:44 PM
kyles2000z's Avatar
do most people jus solve this by puttin the spacers in their springs?......but then again i want the one that is off the be LOWER, not higher, i guess ill hafta just deal with it
Old Oct 11, 2005 | 07:44 PM
2_wacko's Avatar
Does this happen with stock springs or aftermarket?
Old Oct 11, 2005 | 09:20 PM
kyles2000z's Avatar
happens with both
Old Oct 12, 2005 | 12:30 AM
01 Red WS6's Avatar
Ok I'll tell you what I did to fix it for now till I can fix it for good. I got a rubber heater hose and put it on the top coil of the spring. Then I put the factory boot back on too. that raised the passanger side up just enough to almost level it out. It is off maybe an 1/8 or 1/4 I haven't gotten out and measured to get a solid number.
