E-brake maneuvers
A friend of mine had a '96 SS, and if I recall correctly, it had a hydraulic e-brake, almost like it was plumbed into the rear brake lines. Pretty trick if you ask me.
care to elnighten us on your theory of destroying stuff (besides tires), im interested to hear your theory....
-mike peters
professional drifter
fair enough, my cars ebrake's all work fine and i use them probably more than the footbrakes, but this has only been about a year of abuse, still works fine though, lotta drifting, 3rd gear yanks, standing burnouts, if its bad on a car ive done it, and my ebrake still works great.
-mike peters
You drift with an El? How do you do the e-brake? Is it in the normal position with no locking teeth on it?
But, if youre using the e-brake to set up a car going into the corner, you aren't utilizing the car's own power and weight capabilites, IMO. E-brakes typically are used midcorner or for other situations where the tires decide to re-grip in the corner.
IMO, tires for F-bodies are way too expensive to be burning through.
