How hard is it to change out the K-member?
Moderator
Thinking about some weight reduction and I was thinking about a BMR K-member.
How hard is it to change?
Any web site how to's?
and do you have to do the A-Arms at the same time? (Cost you know.)
Just thinking right now.
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Just thinking right now.![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
If you're drag racing only and don't plan to drive aggressively on the street, then you're okay with an aftermarket K-member, but beware, I had two different ones from two different brands, and they both broke around the lower left hand area, so I simply replaced the factory K-member.
Before installing them, I weighed both for a comparison, and only ~10lbs were saved bewteen all of them. When I did install the aftermarket K-members, the front sure started to flex afterwards.
to me 25 lbs is not worth the problems that might come from the kmember
if you drive your car on the street i would not get one
remove the wieght in other places if you want to
