damn Pistons wont go in what to do????
i am changing my brake pads and i have a c-clamp with the old brake pad and i tighten it and tighten it and the damn pistons wont go back what should i do???? please need help asap only car i got. thank you
the clamp is brand new! its crazy we loosened the bleeder screw and all but it hasnt done anything i dont know what is wrong with it we have the clamp tight as hell we needed to add an extension on the handle so we could turn it and the pistons still wont go in
i tryed that too it still wouldnt work. i dont know what the hell is wrong its so annoying now i cant drive anywhere till that is fixed! thanks for the replys guys
I dont know what year the car is or what car your trying to get the piston back in but on some cars the piston actually screws out. There is a tool for getting those pistons back in. There would be to grooves in the piston and the tool looks like a metal rubicks cube without the colors. its universal and each side works on a diffrent caliper piston. If your problem is the rear pistons that sounds like that it your problem get the tool, hook a ratchet up to it and twist away.
Nate
Nate
its on the front brakes i used the c-clamp to compress the other side and it worked fine but the other wont move a millimeter. i will look at the piston and see if there is a groove
