SFC or subframe connectors testemonial
). I had a 1981 Camaro that run 8.6s in the 1/8th on street tires everytime I went down the track until SFCs and lift bars
- 8.16 in the 1/8th on the same 235/60 Goodyears
. Also had a 1989 IROC that had a 5.0 TPI A4 and it would run a 10.08 or a 10.16 in the 1/8th- weird since thats the only #s I got out of it after 2 months of racing lol- bone stock. I know it was blistering fast
, I put SFCs on it and it run the next and therefor following times to the track a 9.96 for the SLOWEST pass- no other changes. I then had a B4C 1994 Camaro that ran 9.0s pretty consistently stock and with just SFCs ran a best of 8.89 in the same weather the next weekend and consistently got low 8.9s. The thing I want to get across is its an investment more than a "mod", although my cars consistently run quicker with em. They help the handling greatly and help the car last longer rattle free(and most of the time cure some you already have). Now that I have put them on my '98 Z I will testify again that any unibody car needs these as a first "mod" and will always testify this. I usually do SFCs right off the bat but didnt with this car....and wish I did
Silas2k- Thanks for the business
Regards,
Ryan
) youl be gettin a call
I plan on buying the 201621 rear arm kit ($264.95) and the 230010 front arm kit ($629.99), my question is the torque arms- the 2202 torque arm looks like what Im lookin for but was wondering if it will clear duals like from TSP? Im runnin the factory catback as of now(and possibly from now on) but might run the TSP duals after my engine swap. Thanx in advance
Item # 201621 is one of our most popular kits and I think you would be very pleased with the performance and results from it. As for the torque arm I am sorry to say that item # 2202 will not clear with the TSP true dual system. If you were to use that system or similar you would need to stick with the transmission mounted style arm. If you wanted to get the torque arm off the transmission we could put you into a torque arm relocation kit but the price then starts getting up there. If you look at the picture below it shows a TSP system installed, you can see were the X runs in the exact place the tunnel mount would be bolted from item # 2202. If I can help anymore please ask and I am glad too.
. I will continue to make plans to run the #2202
. Thanx for the pic- parts I want are on this car- except the torque arm. Do you offer a Kmember? Trending Topics
May not like the hijack, but that's to demonstrate that SFC's can be useful, just not the first thing needed for every application. If you want to improve handling, go right to the source, the suspension itself. Unless the monocoque is well ragged and/or having to drag race with lots of power, SFC's are mostly placebo mod. 3rd Gen definitely need SFC's, but 4th Gens depend on the circumstances. I could've saved money by not listening to my favourite suspension supplier of the time.
Once again, not to hijack, but if you want them, buy them. Personal experience refutes whatever placebo effects exist. The whole "everybody with a 4th gen needs them" and "greatly improves handling and settles all NVH" is largely unsubstantiated.
Again, what shocks are you guys using, and what are their respective valvings, and what springs are used? I'm refering to handling and by what you guys are explaining, your testing is very flawed.
You mention that you're an ASE undercar specialist, however, the SFC's have a lot more to do with the chassis itself. l have spent at least 4 years with my alma matter's SAE club, so they are definitely more familiar with chassis design as they have the appropriate resources for testing and development. Several students have exhuastively tested the efficacy of the SFC for F-bodies for their senior projects, and they have come to the conclusions that I have also. Once again, they have a broad amount of resources at their disposal, including some assitance from several master certified ASE techs with the same amount of experience you have Bo. May seem expensive, but the R&D must be exhaustive in order to pass.
Also bear in mind that every month, I frequent my auto body shop that has the equipment for measuring the chassis geometry points, and they have remained unchanged since 30K miles. All service and repair techs have their respective ASE Bx certifications.
BTW, not to flame Bo, but you mention "undercar" specialist, can you be precise about which certifications? I know of them all, since I frequent the ASE website and work very closely with master certified Bx techs, as well as A4 and A5 techs. I also warn you that SFC's are much more specific to the chassis itself, even though I agree that a crooked chassis indeed negatively affects suspension alignment. Did you work at a body shop, because if the alignment isn't able to be corrected after several attempts, then the monocoque must under go the same test as I mentioned in order to verify that all of the chassis points line up and have their correct symmetry, angles, and length measurements.
Not to bug, but the whole "ramp" scenario? what did you mean by a ramp? If you're talking about a freeway ramp, then I need much more evidence than words, because I have accelerated up many steep ramps, took many equivalent high speed sharp turns of several closed road courses and only my suspension geometry has slightly changed, but is easily corrected, since of course I have my chassis checked, and it too aligns perfectly. Once again, SFC's didn't change this.
I give no commands, especially when it comes to business, however I retain the freedom of civil expression of truth when it comes to this area. I believe that two other members, Cal and Sam have at least a similar experience with what I mention as far as handling, however I'll leave it up to them with their choice to chime in or not.
The reason I ask, is because I do consult some other ASE certified undercar specialists (A4, A5, X1 as well, but at a body shop not with the club) and they aren't allowed to even work, nor perform the chassis measurements, unless they have a B4 qualification. Again I ask this is for clarity and not debate.
My reason I feel that SFC's can be useful for drag racing, and not all around needs is due to drag racers having different suspension needs for the weight transfer involved. Essentially the softer the damper valvings allow for faster weight transfer, the better the performance, and therefore the allowance for the road shocks to transfer, therefore SFC's can have their benefit, but as far as an AX and/or RR, I still think the jury is out there.
