Carbotech Pads...
Old Jan 3, 2006 | 02:15 AM
OneMeanZ's Avatar
Default Carbotech Pads...
Can someone recommend what Carbotech pads to go with, XP9, XP8, or another one? I'll be mostly spirited mountain driving and I'll be going to Road Atlanta and VIR whenever possible. Car is for the most part my daily driver. Thanks!
Old Jan 3, 2006 | 02:22 AM
DONAIMIAN's Avatar
Go with the panther plus. I recomended them to a friend and he just put them on his car, ill see if I can get him to come in and leave some feedback on them.
Old Jan 3, 2006 | 07:57 AM
mitchntx's Avatar
Power and weight of the car?
I'm running XP10s on the front and XP8s on the rear of my CMC race car.
The car is 232/290 and weighs 2950 ...
I ran Panther Plus pads on my '98 street car (400/400 @3500 lbs) with good results.
As with any performance pad, they will dust like crazy. And you need to get that dust off the wheels and car ASAP.
Old Jan 3, 2006 | 09:53 AM
OneMeanZ's Avatar
Thanks guys. Mitch, the car is stock power and stock weight.
Old Jan 3, 2006 | 03:14 PM
DONAIMIAN's Avatar
Hey Mitch, what pads are you running in the rear of the street car?
Old Jan 3, 2006 | 03:31 PM
mitchntx's Avatar
GM stock ...
Old Jan 3, 2006 | 03:59 PM
trackbird's Avatar
I'm currently running my XP8 front (on 6 piston wilwoods) and Panther Plus rears. These are leftover from this years autocross events. If I were were going to recommend pads for a mostly street car (such as mine), I'd suggest Panther Plus on all corners. I've run that combo and it worked great for me.
Old Jan 3, 2006 | 05:12 PM
DONAIMIAN's Avatar
I was gona go with the P+ up front and the bobcats rear, but im not sure on what I want to do with the rears now. A couple of days ago on a freinds car we put P+ up front and wagners on back. After bedding the pads in the rears were smoking and that kinda worried me.
Old Jan 4, 2006 | 07:40 AM
trackbird's Avatar
I ran Panther (before Panther Plus came out) and Super Street rears on a VW GTI that I used to own and that combo worked well. Honestly, the P+ on both ends works well for me. I am using an XP8 since they didn't have the P+ material thick enough to make Wilwood pads (.800 thick, the P+ material is only .625 thick). So, instead of buying "1/2 a set" (ok, 3/4) of pads, I went to XP8's. They work well and I'm even driving them in the snow on snow tires, but they are really hard on rotors when it's cold.
Old Jan 4, 2006 | 08:35 AM
Foxxtron's Avatar
I had thermoquiets in the back as well, and they smoked as they were bedded in, which I can expect from several street pads as they are bedded in as well.
Originally Posted by mitchntx
...And you need to get that dust off the wheels and car ASAP.
And if you leave that dust on your shiny part of your cars paintjob, expect it not to come off easily, unless you use some sort of claybar cleaning system. That was the only thing that seemed to work for me, as well as removing all of that "industrialised" waste stuck on the paints surface.
