View Poll Results: What kind of Motor Mounts
OEM Replacement
15
8.02%
Aftermarket Rubber/Poly type
126
67.38%
SOLID Mounts
46
24.60%
Voters: 187. You may not vote on this poll
Old 01-14-2006, 11:29 AM
02WS6Bird's Avatar
Default What kind of Motor Mounts
On my high mileage 98 Z 28 i have realized that the stock motormounts have become excessively worn. Now I am buying a VERY large cam to put in for cam only AND WILL ASLO BE CHANGING OVER TO A BORED AND STROKED 6.0L Iron block in the not so distant future.
I would like to know what kind of motor mounts would you recommend? jsut a Stock replacement, some sort of aftermarket rubber/poly type motor mount, or a solid motor mount. The car will see very little street time and will be mainly used at the track but of course the occasional cruise.
Which would you recommend? What company etc? Would there be any benefit to solid motor mounts? What about Negatives to having solid ones? Will anything need to be changed for this?
Please state what knowledge you have of this and any suggestions
Old 01-14-2006, 11:33 AM
CashMoney's Avatar
i like the rumble feel.. makes the car feel more like a race car
Old 01-14-2006, 11:46 AM
02WS6Bird's Avatar
Could solid create any problems? anything would be greatly appreciated
Old 01-14-2006, 11:56 AM
02WS6Bird's Avatar
W/ solid motormounts, the rear wouldnt be able to sag so i could bolt up the transmission more easily would it? or does it still for some odd reason allow that to happen?
ttt fellas!
Old 01-14-2006, 11:59 AM
CashMoney's Avatar
Well is anything is loose it'll vibrate.. be prepared to do some tightening.
Good point on the sag thing.. but you could back the bolts out some to sag the rear of the engine if you need to. I haven't done a clutch yet in my car. And my friends car we did the clutch before the motor mounts.
Old 01-14-2006, 07:23 PM
GTObsessor's Avatar
At the VERY least go with poly mounts... it'll pick up some serious slack in the drivetrain and you could go with solid - you'd get lots of vibration but if it's mainly a track car, who cares?
Old 01-15-2006, 08:40 AM
02WS6Bird's Avatar
ttt fellas
Old 01-15-2006, 09:26 AM
Josh@KY-Turbo's Avatar
solid mount. i dont like all the loose stuff making noise, but then again i am going solid roller and a nasty cam so its gonna vibarate anyway.
Old 01-15-2006, 12:07 PM
SUX2BU's Avatar
i daily drive solid motor mounts and you can't even tell they're there.
Old 01-15-2006, 03:48 PM
JamesO WS6's Avatar
side note, ttt?? Whats that mean?
"Thought That Too"?
Old 01-15-2006, 06:32 PM
SUX2BU's Avatar
to the top.
Old 01-15-2006, 07:14 PM
bad6as's Avatar
bolt ons.....stock mounts
bad *** street car that sees the track.........enegry suspension or prothane, prothane is harder
track car, that see a lil street.....solid
Old 01-15-2006, 07:27 PM
P Mack's Avatar
I have prothane and love them.
Old 01-18-2006, 01:23 AM
HAMRHEAD's Avatar
Go with the solid motor mounts. The vibration shouldn't be to bad.
Old 01-18-2006, 08:25 PM
SUX2BU's Avatar
Ok people that are saying solid motor mounts for a race car, how many of you have actually driven an LS1 with solid motor mounts?
when i threw mine on i noticed absolutely no viberations or anything. all it did was feel like i had put a better torque arm on. the car felt like it was putting the power to the ground ALOT better.
The only side effect i did notice was the cold start knock that my motor had got conciderably louder cause it was now transfered throughout the car. but it went away after it reached operating temp just like normal.
Old 01-18-2006, 09:38 PM
02WS6Bird's Avatar
Well i've decided to go w/ the BMR Motormounts I guess they are Prothane motor mounts. Sites kinda confusing. Only problem w/ them is they are on backorder now (if anybody has any info on this please plet me know) thanks everyone for your input and see ya'll on the track. Your info is greatly appreciated
Old 01-19-2006, 09:03 AM
Tobynine9's Avatar
I've heard that solid mounts can break the tailshaft/shifter housing with excessive vibration/torque. Is there any validity to that?
Old 01-19-2006, 12:36 PM
DAPSUPRSLO's Avatar
I've heard rumors of solid motor mounts causing issues with wet sleeved blocks (stressing the block causing distortion)? Is this just a rumor or is their any truth to this? Thanks.
Old 01-19-2006, 05:56 PM
SUX2BU's Avatar
unless you put a solid mount on the tranny (wich is pointless) your ok.
Old 01-19-2006, 05:57 PM
SUX2BU's Avatar
i think one guy that was makin some crazy HP a while ago (i believe like 800+hp). had some issue like that.
Quick Reply: What kind of Motor Mounts
