ok guys what lowering springs are you running with longtubes?
I'm using Suspension Technique springs. Only a 1.2 inch drop, good if your running headers. I also have a TSP 3" catted Ypipe, and ground clearance is still pretty decent.
If your worried about traction, relocation brackets are a must. Even with just the 1.2 inch drop my traction went to ****.
https://ls1tech.com/forums/suspension-brakes/450388-anyone-dared-lower-their-car-w-tsp-y-pipe.html
Pacesetter longtubes with Hotchkis springs. The headers clear fine. The y-pipe tends to scrape, but not nearly as much now that I have decent shocks.
-Mike
-Mike
Originally Posted by minesfaster
How does lowering your car make your traction bad ?
I'm running Sportlines with Kooks and haven't had any scraping problems.
Lowering your car does decrease your traction because it changes the pinion angle. That's why it's a good idea to get relocation brackets for the lower control arms; to correct lost pinion angle and increase traction.
