Stainless brake lines.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I have Earl's. I don't really know if they are worth it because I have yet to make it to a road course.
They are not bad at all to install and probobly worth it as long as you track your car a lot.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
1 Post
Originally Posted by JimMueller
I've had Earl's lines on mine since 1999 and added the speed bleeders a year or so ago. Not a single problem and the bleeders work great. Can I tell the difference? No. Do I open track? No.
T-Rex, what are you using them for? If you're just stopping at redlights on the street, probably not worth it. After all, you're going to just hit the brakes hard enough to make you stop, in a straight lint.
For autox, I'd say spend your money elsewhere. They're not bad, but most of the time you're trying to stop in a straight line and putting the pedal to the floor. Stainless lines will not give you any more stopping power than rubber.
But, for track use, they're very helpful. SS lines don't expand, meaning that every twitch of your pedal means a corresponding change to the pressure applied at the pads. Also, it means that you'll feel more feedback coming back through the brake pedal, so you know what's going on at the wheels (are your pads getting too hot, is your rotor warped, etc.).
This is especially important when you're in the middle of a corner and are just trying to brake at 43% so you can get the nose to tuck into the corner a bit more. You can't get 43% with rubber lines because of the mushy pedal feel caused by minute expansions and contractions of the rubber lines. You can get 50%, which is going to scrub off too much speed and hurt corner exit. You can get 40%, which isn't enough and will make you miss the apex of the corner. But, you just can't hit 43% every time.
I thought rubber lines do not expand since they contain a braided liner and must meet federally approved specs; right?
Anyway; I suppose they are a cheap upgrade that won't "brake" the bank.
