lowering and shocks
Old Mar 5, 2006 | 09:57 AM
dit666's Avatar
Default lowering and shocks
i want to lowr my car im thinkin eibach springs and billstien shocks is that a good combo? I know thats what they use o the slp camaros ...also if i lower am i gonna need an ajustable panhard rod, and if so is the ajustable one as strong as the non- ajustable Im in need of suggestions guys...thanks
Old Mar 5, 2006 | 09:59 AM
dit666's Avatar
by the way i have a 2001 SS Camaro... this is the car im tryin to lower....
Old Mar 5, 2006 | 06:14 PM
Flawless02SS's Avatar
if it not a serious track car or autocross car, it doesnt really make a big difference.
Old Mar 6, 2006 | 03:17 AM
chipz's Avatar
^ same as above IMO
Old Mar 6, 2006 | 08:20 AM
02SS0384's Avatar
If your talking about the SLP Eibachs with the SLP Bilsteins then they are matched. But if your talking about the Eibach Pro Kit and regular Bilstein HD's I would say no. The SLP suspension stuff is different than the regular Eibach and Bilstein.
My best advise to you would be to call Sam Strano.
Old Mar 6, 2006 | 09:05 AM
LS69TA's Avatar
If you lower you'll need an adjustable PHR. Get some revalved Bilsteins from Sam Strano if you're set on that brand. Koni shocks would be a good choice also.
Old Mar 7, 2006 | 09:56 AM
dit666's Avatar
Default ok
any other suggestions i want my car to handle great and look good
Old Mar 7, 2006 | 12:55 PM
May Spin's Avatar
Couldn't be further from the truth..... His spring choice will not only determine the drop but there is a plethora of spring rates to consider, which will dramically change the ride and handling characteristics of the car. Not to mention the correct choice of shock valving.
dit666..... IMO, your selections will make a HUGE difference on your enjoyment of the car. I second a call to Sam Strano if only to educate yourself.
Scott.
