Brake Fluid Flush
Old Mar 5, 2006 | 10:27 PM
Z28-CTYHNTR's Avatar
Default Brake Fluid Flush
Well since the search function is all jacked up right now, Ill go ahead and ask this question even though Im sure it was answered long ago. Anyway, Im considering flushing my brake system myself, so Im curious what is all involved in such a task. From what I know, I just bleed each line while pouring new fluid in at the MC until clean fluid comes out, then switch to the next line and repeat. Is this correct?
Old Mar 5, 2006 | 10:33 PM
Racer8102's Avatar
Not sure on just a flush, but I just put new brakes on my car, different calipers and rotors and all of the fluid out of the master cylinder, and I started with the pass side rear, driver rear, pass frt, diver front. I was very obvious when the new fluid came through compared to the old. I think there is some stuff you can run through for a flush, its blue or green colored so you can tell when it comes through, but I just put in new fluid and bled each bleeder screw (strange brake calipers have 4 bleeders on each caliper), it took almost three bottles to fill mine up and bleed. Hope this helps
Old Mar 6, 2006 | 09:54 PM
mitchntx's Avatar
Suck as much out of the MC as you possibly can with a turkey baster
refill the MC
bleed at each wheel ... pass rear, driver rear, pass front, driver front
Keep the MC full. Use a full quart rotating around to eachcorner after about 15 or so pumps.
Or you can just let it gravity bleed ...
Old Mar 6, 2006 | 11:03 PM
Cool, thanks for the info guys.
Old Mar 7, 2006 | 02:05 AM
Predator's Avatar
Get yourself a pair of bottles, then gravity bleed, or enlist the help of a friend to pump the pedal. I picked up a couple sets of Earl's Solo Bleeders so I can quickly bleed them myself, but the bottles are the most important brake bleeding tool to have.
Attached Thumbnails Brake Fluid Flush-motive-products-brake-bleeding-catch-b109.jpg
Old Mar 8, 2006 | 01:34 PM
z28bryan's Avatar
What do you guys mean by "gravity bleed"?
Old Mar 8, 2006 | 06:38 PM
67Ranger's Avatar
just open the bleeders up and let it kindof drain out into a bottle. It will get some of it out, but take a while.
Old Mar 9, 2006 | 06:48 AM
Ateyate's Avatar
Anybody use a Mityvac pump? I think I'm gonna try one.
Old Mar 9, 2006 | 07:10 AM
Dans2000SS's Avatar
I have their pneumatic model and it works great.
Old Mar 9, 2006 | 09:39 AM
I was tempted to use a pump but I was worried I might suck too much out too quicly. But then again Im not even exactly sure how they work.
Old Mar 9, 2006 | 09:51 AM
Dans2000SS's Avatar
There is a valve to adjust the flow rate. I used super blue fluid so it was easy to tell when all the old fluid was out.
Old Mar 9, 2006 | 12:12 PM
Ateyate's Avatar
Excellent, that seems like the easiest way to do it by yourself. Thanks!
Old Mar 9, 2006 | 03:49 PM
DONAIMIAN's Avatar
I went to the hardware store and picked up some clear plastic tubing (basicly the same stuff used on your bottle) and a 1 gallon water jug.
Old Mar 25, 2006 | 08:07 AM
2002 Trans Am's Avatar
Anyone know approximately how much brake fluid I should buy?
Old Mar 25, 2006 | 09:03 AM
mitchntx's Avatar
If you know what you careful you can get away with a litre.
Old Mar 25, 2006 | 09:47 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
I bought 3 bottles of 500 ml (Brembo Evo 500 fluid), that way I have extra for bleeding.
Old Mar 25, 2006 | 01:53 PM
Bill's 02 Z-28 SS's Avatar
Hi Folks
Look at Eastwood's site - they have a Brake bleeder that keeps a continuous supply of brake fluid in the reserve. Maybe one of the sponser's has one also. Also start from the farthest point from the master cylinder, and so on, so on. If you don't have a force feeder, continuously check the master Cylinder.
Bill
Old Mar 28, 2006 | 04:45 PM
Racer8102's Avatar
I bought 3 bottles after installing the strange brakes on all four corners, so I know everything was completely empty, and I had about half of the third bottle left after bleeding.
Old Mar 28, 2006 | 11:46 PM
BTW I did it over the weekend. Used 1 full bottle of valvoline synthetic (64oz)
Not bad for around 5 bucks....I also bought one of those mityvac things, works ok at best, just wish the fittings were better.
Also Mitch if you could answer this for me. My front driver side was DIRTY AS ****. It was far dirtier than any of the other 3 and had a lot of particles in it. Does my caliper need to be rebuilt, or is this common since its closest to the master cylinder?
Old Mar 29, 2006 | 01:28 AM
mitchntx's Avatar
It most likely means that the caliper guide pins might be sticking a bit or the caliper pistons are sticking.
Does the rotor/pad show abnormal wear?
