STB or PHR
Hi, just got my paycheck and ready to blow a hundred or two.. I'm just curious what each would do for my car and which would be worth spending my money on. Thanks..
Neither.... both would be a waste of money at this time, unless you like eye candy, then I guess a STB would be nice. Save your money.... Good Shocks is the single best improvement you can do.
Shocks. If you are heart set on choosing between the strut tower brace and the panhard, get the panhard, although there isn't much point if the car isn't lowered. What is your goal with the car (ie what motorsport if any), street...etc
If you're planning on lowering, get an adjustable panhard bar. If you want a mod that will make a bigger difference right away, save up for good shocks or a set of bigger swaybars, like a 35mm/21mm combo.
-Mike
-Mike
I disagree, I made the lca and panhard upgrade early in the mod list , as well as upgrade to the adj torque are, I thought I got a lot of performance in the handeling department for the money, and I spent less than the cost of 4 shocks.
LS1TECH Sponsor
shocks, shocks, shocks.
Then swaybars.
PHB would be much wiser than a STB, but also not near as important as the PROPERLY PICKED shocks and/or swaybars.
Car has a PHB stock. Not the coolest thing in the world, but some cars don't even have such a setup stock. Matter of degrees folks. There is very little wrong with the stock PHB, the same cannot be said for the stock shocks bars and other things.
Then swaybars.
__________________
LS1TECH Sponsor
I see you are from Greensburg. I had a nice gentleman from there come up here once. He rode in my car which at the time had just shocks (Koni's) and a front swaybar upgrade. His car has SFC's, PHB, LCA's, STB.... everything *but* good shocks and better swaybars. One ride in my car, and he bought those parts from me. He's even on this boards, I believe his screen name is something like 1quikws6 or something like that. You might know him.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
STB does look look good but does not do much. PHB look good and u can feel. Get the poly / rod end one from spohn. Byun speed has good price. Shocks will make more of a difference, for the better.
Originally Posted by 01 Trans Am
i plan on lowering the car and adding a cam+nitrous. other stuff down the road..
Just a thought in a different direction, I noticed in your mods a short throw shifter wasn't listed. I would spring for that before the PHR or STB. If you had that or your set on the two above listed items, then I would go for a APHB.
