shock tower brace....good mod?
To me, all it has been useful for so far has been that I can use it to lean onto when I am tired working on the car
I have figured since 4th gens do not have struts, a strut tower brace doesn't do much, if anything, as far as improving the handling. I have an almost stock suspension 1994 Z28 with a STB and a stock-suspension 1998 Z28 without an STB, and I don't feel any difference in the way both cars understeer or transition from side-to-side. Good luck.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
here's a thread that can be merged into this since a nearly identical enquiry was used by the thread starter.
https://ls1tech.com/forums/showthrea...=479494&page=1
The ultimate mod is to wind copper wire along the length of the shaft, apply current and the resulting EMF will give you a positive charge on the air in the intake.
This positive charge "excites" the fuel when they mix in the chamber and it results in a 20% cleaner burn.
Guaranteed 50hp and cooler temps. The more current, the more power. It's a renewable energy source to replace nawz.
It will also clean up the emmissions for easy passing of smog tests.
Sweet!
Sweet!
Sweet!
Sweet!
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Premium 12 gauge wire-wound STB's now being offered from Cal's Machine shop! Heavy duty alternator and voltage regulator included with kit, only $899.95 limited time offer! Both right-hand and left-hand wound bars available; choose wire-wrap/flux direction based on cornering direction you wish to optimize.
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
LOL
I was convinced that it the STB's were useless on our cars until a buddy of mine GAVE me one and said hey just try it, it's free. I slapped it on and I felt a difference right away. I think it's kind of like the SFC's, the older the car is, the more effect it's going to have.
Oooh, where do I sign up?
