View Poll Results: Get ride of abs stuff or keep it?
ABS delete
33
50.00%
Just line lock kit
33
50.00%
Voters: 66. You may not vote on this poll
Line lock kit and delete abs?
Old Oct 3, 2006 | 11:25 PM
ninobrn99's Avatar
very nice.
Old Oct 4, 2006 | 04:12 AM
Doc's Avatar
Doc
Thanks man, I just noticed how crappy of a picture that was I think it wasn't that great to begin with and then I reduced it to post and well it turned out kinda crappy. When I arm the line lock with the Master switch in the ashtray the led light on the TCS button lets me know the ckt is live. Steve(SJM), you should put together a premium line lock, ABS delete kit that has these switches
Old Oct 4, 2006 | 08:17 AM
SJM Manufacturing Inc's Avatar
. Doc, thanks for your post and comments. All our kits !ABS as well as even just the line lock kit which include LL circuitry have similar switches as well as remote LED indictor.
All !ABS kits include a proportioning valve which is an important feature to correctly bias your front/rear brakes since ABS is now non-functional.
Old Oct 4, 2006 | 03:15 PM
ninobrn99's Avatar
Steve, how do you adjust the brakes? meaning how does the proportionating valve work??
Old Oct 4, 2006 | 04:55 PM
Directions are included in the kit. A proportioning valve adjusts front/rear pressures so that you are able to utilize front and rear brakes to its fullest potential.
Old Oct 4, 2006 | 04:58 PM
bad6as's Avatar
On the ABS connector make up a jumper wire (about 1 1/2") with soldered ends and insert one end into pin 7 and the other into pin 12. The ABS module provides the logic ground if the system is ok. So just ground out that pin 7 to 12 (grnd) and bingo.
so it i put a wire in pin 7 and the other end of that wire in pin 12.
my abs inop light will go out, and my brake light will go out.
does the brake light still work as it would with a stock rear?
and does that make the car think that it still has abs, or does it just make it go out?
Old Oct 4, 2006 | 06:29 PM
ninobrn99's Avatar
ah ok..thanks again steve.
Old Oct 4, 2006 | 07:45 PM
94CamaroLT1's Avatar
does doing this cause your abs inop light to come on becuz i dont have a abs system but i do have a line lock and my abs inop light comes on? any one else have this problem
Old Oct 4, 2006 | 08:04 PM
jimmyblue's Avatar
Moderator
I do so want to do this kit, but ABS has saved my *** (or
nose, more properly) one time so I'm reluctant to part with
the safety net. If it were a track car, or I just had better
panic-stop instincts, then hell yeah.
Old Oct 4, 2006 | 08:09 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I have the same feeling as you, but unlike you, I've never had to use mine (knock on wood). I think I'm just gonna bite the bullet and get it...the car I learned to drive in didn't have traction control or ABS, and it got me through snow and ice without issue. Granted it was a 1992, 4-door, FWD Plymouth Acclaim
Old Oct 4, 2006 | 08:14 PM
LS1SpeedAddict's Avatar
Anybody have pictures of their engine bay with the ABS removed?
Old Oct 5, 2006 | 11:53 AM
  #32
Here's a few customers setups one before !ABS, one after !ABS and one of our LL setups (since this is a poll of which to choose).
Attached Thumbnails Line lock kit and delete abs?-before-abs-delete.jpg   Line lock kit and delete abs?-after-abs-delete-install.jpg   Line lock kit and delete abs?-sjm-2b001blackmodified.jpg
Old Oct 7, 2006 | 03:40 PM
  #33
Chased's Avatar
I have a 96 lt1 going to buy the kit for the slp line lock.....but whats does the 3 channel-4 channel option mean???
car had traction control and abs factory if it ahs something to do with that?
Old Oct 7, 2006 | 10:08 PM
  #34
If your car had traction control, then you'd need to order the 4 channel kit. Differences are what is included in the kit to adapt to what your car currently has.
Steve
Old Oct 10, 2006 | 12:21 AM
  #35
Camaross124's Avatar
man **** that thing is bomb as ****... did you just buy the button from GM? i was thinking about just setting a switch next to my vert top switch like that for line lock...
Old Oct 10, 2006 | 01:48 AM
  #36
Gun5's Avatar
where do i get that plate that goes in that hole??
Also SJM i had a few questions, I got a 1994 Formy.. changed to series 2 3.73's don't have ABS anymore also I dont think the car ever had TCS (no botton and never worked atleast lol) I'm kinda strapped for cash I just finished building the car (im almost 18 here) I want to get rid of that ugly ABS box.. line lock would be nice and that proportioning valve seems like its a must
Old Oct 10, 2006 | 06:34 PM
  #37
Gun5's Avatar
bump tttt
Old Oct 10, 2006 | 08:13 PM
  #38
black_z's Avatar
Steve, will the ABS delete kit remove TCS also? I am looking to shed some more weight from the car and strongly considering a linelock/ABS delete kit.
Old Oct 11, 2006 | 07:39 PM
  #39
PurEvl's Avatar
Originally Posted by ninobrn99
Sweet. Thanks for the info Steve! If I cant get my ABS light to go away and fix my problem, then Im going to do away with it altogether!
Nino
be prepared when you do the abs delete block, you will have a service vehicle light on and the brake light on all the time too. I have my abs deleted with the block as well
Old Oct 11, 2006 | 07:40 PM
  #40
PurEvl's Avatar
one other question ive got. what happenes to the codes? when u go for inspection or anything of the sort, wont that code show?
abs codes dont go against failing, mine passed fine with them on. Not all cars have abs, its a luxury not a requirement
