SFC, which is the best
i'd like the peace of mind knowing there's no bolts to come loose.
I honestly dont think there's an "outright" best in talking about subframes. Especially when you might be comparing 3 points vs 2 points, weld ins vs bolt ins or tubular vs boxed. All of them do the job just fine, its mainly personal preferance.
Also you have a vert so that is going to be an issue. Some companys SFC's only fit coupes so check that out before you buy them.
I installed the shock tower brace, no problem. The SFCs were another story, however. Long story short, they just didn't fit correctly. At first, I thought it was just a case of a little filing and fitting, as cars have production tolerances. But the more I filed to fit the rear rocker area, the more it threw off the front frame to connector alignment. Also, they almost pinched the fuel line harness to the floorboard.
I messed with them for a few weeks, then gave up, and I installed Kenny Browns instead....
