hose mod?
Old Apr 6, 2006 | 04:27 PM
rjkZ28's Avatar
Default hose mod?
hey guys whats going on? im going to be re doing my suspesion again, and was trying to figure out what the hose mad was that i keep hearing about? and there is another one i believe for the front, if someone can shine some input on this that would help out alot thanks!
Old Apr 6, 2006 | 04:31 PM
jmm98LS1's Avatar
Hose Mod:
(you should have searched first) This is where you remove the rear spring rubber isolator and put some heater hose over the top coil to keep from punching a hole in the upper spring cup. Usually lowers the rear about 1/2".
Old Apr 6, 2006 | 04:48 PM
rjkZ28's Avatar
ok cool thanks, whats the mod called for the front to drop it? mind u im putting eibach pro kit on my car.
Old Apr 6, 2006 | 04:51 PM
jmm98LS1's Avatar
Never heard of a mod like that for the front.
Old Apr 6, 2006 | 04:56 PM
rjkZ28's Avatar
ok though maybe i did. now my concern is that i herd eibach start to sag in the rear, im lookin for a little bit of a rake to my car, so im not sure if im gonna do the heater hose mod, but where get i these poly spacer ive been hearing about to put in the springs or somethin? can i order them from summit? and where excatly do you put them in the springs, top, middle, or bottom?
Old Apr 6, 2006 | 05:28 PM
rjkZ28's Avatar
would this spacer work to help with the sag of the eibachs? and do u think its worth doing? http://store.summitracing.com/partde...5&autoview=sku
Old Apr 6, 2006 | 08:18 PM
jmm98LS1's Avatar
Take a look at my sig pic. I've got the prokit and have had it for nearly a year and have not experienced any rear suspension sagging. My impression is that the newer kits don't have this problem. If you're looking for a slight rake, I'd put the prokit front springs on, leave the stock rear springs and do the hose mod to drop it just a little, but not as much as the fronts. My .02
Old Apr 7, 2006 | 04:11 PM
rjkZ28's Avatar
the only problem with that is that 1 i dont have the stock springs anymore and 2 im getting bilstein re-valved made for the eibach prokit.
Old Apr 7, 2006 | 08:43 PM
damon_Z's Avatar
Use the lower spring perch on the Koni SA?
Old Apr 8, 2006 | 12:24 AM
rjkZ28's Avatar
where can i purchase this lower spring perch and what will it do excatly?
Old Apr 8, 2006 | 05:38 AM
Honda Hunter's Avatar
What size heater hose?
Old Apr 8, 2006 | 07:13 AM
damon_Z's Avatar
They're on the front Koni SA shocks and, if used, will lower the front by 3/4 inch. Do a search on Koni SA for more info.
Old Apr 8, 2006 | 07:34 AM
shudog's Avatar
This is the setup I have on my car: Koni SA's all around with stock springs. Front has Koni's on lower spring perch and rears have the hose mod to remove the rear rubber isolator. I'm very pleased with this setup. It's not a drastic drop which is good but the handling was definitely improved and it does get rid of a bit more of the wheel to fender gap. Plus it's cheap and easy to do.
Old Apr 9, 2006 | 12:40 AM
rjkZ28's Avatar
well i ordered the bilsteins re-valves, they should be here this week
