quick brake caliper question
The dupli-color kit has a very nice gloss to it once it dries. Looks as if you sprayed it with clear coat. You'll need to apply 2 coats; maybe a 3rd if you want. I did 2.
Another thing, remove as much brake fluid from the master cylinder as possible before hand. Try using a turkey baster. And have a can or bottle handy to catch the little bit of fluid that will be running out of the brake line(s) once you brake it/them loose.
