Why does my rear want to kick to the side when shifting gears?
Old 04-18-2006, 06:23 PM
Marc '99T/A's Avatar
Question Why does my rear want to kick to the side when shifting gears?
Adjustable PHR, tubular LCA's & SFC's, shitty springs and shocks (new ones are en-route), stock sway bars. All bolts are tight. This is kinda driving me nuts. I have a feeling that it is related to my gears not being set properly. Could it be? If not, any other ideas???
Old 04-18-2006, 06:37 PM
slmdLS1's Avatar
i've always been told thats due to the rear sway bar(or was it the Panhard bar). but mine doesnt do that.
Old 04-18-2006, 06:47 PM
I've already switched between two different brands of panhard bars, so I don't think that's it.
Old 04-18-2006, 06:49 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Question
not gears...........your rear might be off-center maybe... JUST noticed you said 2 panhards >??? are one of your control arms broken?? does your rear look centered..measure how far your tire sticks out from the fender on each side....that will tell you if you are off-kilter...
Old 04-18-2006, 06:51 PM
nope, that's good.
Old 04-18-2006, 06:53 PM
NHRAMAN's Avatar
okay--check control arms for sloppy/break..spring not on the perch???
Old 04-18-2006, 06:57 PM
NHRAMAN's Avatar
Question
loose shock ?????
Old 04-18-2006, 06:59 PM
what do you mean sloppy/break? lca bolts are secure; haven't checked the shock bolts.
Old 04-18-2006, 07:00 PM
NHRAMAN's Avatar
Exclamation
Go check em' if none of these things are loose/broken, your rear MUST not be centered man...I have heard of this problem before..it HAS to be centered properly or else it will not track straight--you have heard people say they saw a truck 'Dog-Legging' it down the road ?? thats what it means...maybe get a friend to drive behind you for awhile..30-40 mph is fine..don't need to boot it or anything..see if you are tracking straight.
Old 04-18-2006, 07:04 PM
NHRAMAN's Avatar
Exclamation
meant loose or broken.........
Old 04-18-2006, 07:18 PM
NHRAMAN's Avatar
Question
Find the problem ???????????????
Old 04-18-2006, 07:26 PM
JustAnIlluzion's Avatar
loose lugnuts maybe
Old 04-18-2006, 07:27 PM
Ok, I just went and checked. The rear is centered, and the lower shock bolts are tight. My new shocks / springs are coming in sometime this week, and I'll check the swaybar bolts when I get the rear jacked up and the tires off. Anything else I should check for?
Old 04-18-2006, 07:30 PM
Originally Posted by JustAnIlluzion
loose lugnuts maybe
come on, give me some credit.
Old 04-18-2006, 07:34 PM
NHRAMAN's Avatar
Lightbulb
can't think of anything more really...shocks,lca's,springs,panhard/off center..........[lug nutty's] try what i said with another vehicle behind you....if it tracks fine..??? how about 1 bald tire and 1 with new tread ???? angle of a particular road.??? Global warming.. [sorry,I had to]
Old 04-18-2006, 07:40 PM
Tires are good, less than 5K on GS-D3's. I'll check the tracking idea. I'm starting to lean towards global warming or el nino.
Old 04-18-2006, 07:56 PM
NHRAMAN's Avatar
Cool
FORGOT about the NINO-MEISTER....
Old 04-18-2006, 07:59 PM
Old 04-18-2006, 08:27 PM
navymitch12's Avatar
i am just throwing a shot out in the dark but could one of your shocks be shot and the other one good..... making the rear twist a little more.... or something like that?
i could be totally wrong but it seems like you have checked everything else and you said you have old shocks on there
Old 04-18-2006, 08:31 PM
could be, i dunno. i'll find out this week when i replace the shocks / springs.
Quick Reply: Why does my rear want to kick to the side when shifting gears?
